Jandy Aqualink - Rs24 One Touch Pool / Spa Combination Control System Logo
H
Harrichand Sukdeo Posted on Oct 09, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to reset my one touch lite in house panel unit
David Spradling
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • Jandy Master 1,448 Answers
  • Posted on Oct 15, 2014
David Spradling
Jandy Master
Level 3:
Renaissance:
Answers
1448
Questions
Helped
518459
Points
1901
Go to system set up and set the back light
INTELLITOUCH REMOTE CONTROLLER WILL NOT COMMUNICATE WITH OUTDOOR PANEL
Resyncing the Pentair Mobile Touch
To reset the Pentair Mobile touch after receiving data retrieval error when using any of the function buttons.
    1)From main menu select the menu button.
    2)Then select setup.
    3)Then select advanced.
    4)Then from the 4 lower buttons select 2 and 4 simultaneously. (Secret Buttons)
    5)Then select MAN Address lock button, (4th button down on the left), you should see a number displayed at the top.
    Go to outside main panel.
    1)Hit the reset button on the right side of panel.
    2)The three system control led's will illuminate for approximately 10 seconds.
    3)Select the F button
    4)Then the led's across the board will start to cycle in order, searching for a house address.
    5)Then after 30 seconds the system control led's will flash a number code The led's are numbered 1-8 plus the heater led is 9, and the solar led is 0
    So you will see the code being flashed example 1,6 (Yours will be different) ,over and over until the reset button is once again pushed, but do not push it yet.
    Go back to the remote you will see a number at the top of the screen, (Be sure you have selected the MAN from previous) you can change It by selecting the + or - button enter the same number code you got from the panel. Our example 1, 6 (yours will be different), select save, and reset the outside main panel.
    You are now done!
1helpful
Just received a used ds lite from ebay. when I type on the screen it enters the letter next to the one I touched. Is this a serious problem? Never used a DS before; will this have an impact on game...
Sounds like you should try recaliberating the touch screen. Calibration must be done with a stylus. Please note: Using a unlicsensed screen protector can lower the sensitivity of the screen, making calibration difficult. If the problem you are encountering started happening after installing a screen protector, this may be the cause of the problem. Remove all games from the Nintendo DS. Turn the system on by pressing the POWER button. Press the A Button when the "Touch the Touch Screen to continue" message appears. When the main menu appears, use the Control Pad to to place the cursor over the Settings Menu Panel at the bottom of the screen, and press the A Button. should look like this :
icon_settings.gif Use the Control Pad to place the cursor over the orange icon that looks like crosshairs (the right-most icon), and press the A Button. should look like this:
    icon_calibrate.gif Use the stylus, and tap the red square that appears on the screen. Do this each time the square moves. You must touch the red square precisely at each of the three positions, otherwise the test will continue to re-start If the touch screen is not responding properly, hold the Nintendo DS at an angle so that you can see where the edges of the Touch Screen meet the housing of the system. Look around the entire edge of the Touch Screen for any foreign material (such as crumbs, etc.) that may be wedged in between the Touch Screen and the housing of the DS. Foreign material in this area can cause the Touch Screen to work incorrectly. When complete, four squares will appear, allowing users to test the touch screen sensitivity. (Testing is optional.) Tap the "Confirm" button in the lower-right corner. Wait for the the confirmation message to disappear, then tap "Quit," then "Yes" to exit. The unit will shut down automatically to save the settings. hope this helps
1helpful
Nintendo DS Lite keyboard problem
Recalibrating the Touch Screen
Remove all games from the Nintendo DS Lite.
Turn the system on by pressing the POWER switch.
When the main menu appears, use the Control Pad to place the cursor over the Settings Menu Panel at the bottom of the screen, and press the A Button.
Use the stylus, and tap the red square that appears on the screen. Do this each time the square moves. (Note : You must touch the red square precisely at each of the three positions, otherwise the test will continue to re-start.)
Will not lite. checked hsi without touching
Sounds like air in the line, just crack the gas line coupling or connection till you smell the gas scent and retighten lines and wait a few minutes till the air clears around the unit and fire it back up.!T Y V Much!
Dacor Microwave Touch Screen lite but blank
You can get that repaired for $39.95 in most cases (details here) or order a control / display unit here and replace it yourself for just over a hundred.
My screen is lockedI did a hard reset and screen wont respond
ur touch panel is faulty u have to go to service centre , there are 3 things coupled together Lcd screen then touch panel and then front housing for protection of both , u might dropped it , if ur screen is working partially i mean if it responds to taps at some region of screen then it may be a dust inside the housing u have to clean it from inside if u can , otherwise if it completely not responding then it is faulty touch panel , it will cost u around 50 , 60 $
3answers
Left side of the screen not responding
  • Be sure that you're using only the bottom screen of the Nintendo DS Lite with the stylus. The upper screen is not a touch screen.
  • Unlicensed screen protectors can lower the sensitivity of the touch screen. If the problem you are experiencing started happening after you attached a screen protector, you may want to remove it. Please note that some screen protectors can leave behind a residue that may be difficult to clean. If you are planning on removing a screen protector that has been placed on your Nintendo DS Lite
  • If the touch screen is not responding when touched, or the accuracy of the screen is off, you may need to recalibrate the touch screen.
    1. Remove all games from the Nintendo DS.
    2. Turn the system on by pressing the POWER button.
    3. Press the A Button when the "Touch the Touch Screen to continue" message appears.
    4. When the main menu appears, use the Control Pad to to place the cursor over the Settings Menu Panel at the bottom of the screen, and press the A Button.
    5. Use the Control Pad to place the cursor over the orange icon that looks like crosshairs (the right-most icon), and press the A Button.
    6. Use the stylus, and tap the red square that appears on the screen. Do this each time the square moves.
      • You must touch the red square precisely at each of the three positions, otherwise the test will continue to re-start.
      • If the touch screen is not responding properly, hold the Nintendo DS at an angle so that you can see where the edges of the Touch Screen meet the housing of the system. Look around the entire edge of the Touch Screen for any foreign material (such as crumbs, etc.) that may be wedged in between the Touch Screen and the housing of the DS. Foreign material in this area can cause the Touch Screen to work incorrectly. If there are any visible particles, clean the screen.
      • If the above steps did not help, there is a problem with the system and it will need to be repaired.
    7. When complete, four squares will appear, allowing users to test the touch screen sensitivity. (Testing is optional.) Tap the "Confirm" button in the lower-right corner.
    8. Wait for the the confirmation message to disappear, then tap "Quit," then "Yes" to exit. The unit will shut down automatically to save the settings.
    3answers
    Mitac Mio 168 won't go past ALIGN SCREEN
    The touch panel on the LCD unit is defective and needa to be replaced with a new Compleet new LCD+TP unit.
    If you have a screen gaurd on your Touch panel, try to remove it and check again, if it doean't help ---> new LCD+TP unit
    1helpful
    4answers
    Maytag Dishwasher
    we have a model mdvtt53aww1 and you can push three buttons and will light up the hi temp wash, heated dry and sanitize is there a code make it start
    Oct 01, 2007 • Dishwashers
    Reset Microwave after a Power Outage
    If its part of the house your renting, call the landlord as its most likly a control panel went bad, and in this unit, thats probably going to exceed the cost of the microwave oven. If its a rental oven, take it back.
    Top Jandy Pool & Spa Experts
    David Spradling
    David Spradling
    ZJ Limited
    ZJ Limited
    john h
    Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
