GE Zoneline AZ55H07D Air Conditioner
Problem for GE Zoneline AZ55H07D Air Conditioner
AMANA PTH153B35AE PTAC Temp drop??
By munrys on Jul 04, 2009
How many degrees is the unit suppose to drop the temp from the input to the output. The unit is about 5 years old and it use to cool better. It's only dropping the air temp thru the AC about 12 degrees. I have cleaned the outside and inside coils with cleaner. They look better but still doesn't cool as good. Also after cleaning the compressor doesn't seem to stay on as long as it did before I cleaned it. ?? I can't check the charge because it doesn't have any place to connect the hoses too. Any help would be appreciated.
Comments:
Jul 06, 2009
- Rus, Thanks for your reply. How do I check the TD air and what and where is it located? How do I find a tech that works on PTAC units or do all AC tech work on them?
Solution #1
posted on Jul 05, 2009
Not Rated)
james3751
Rank: Guru  Air Conditioners  Expert
Rating: 91%, 214 votes
PTAC temp drop should be 20 to 25 degrees across the coil. They never put a service tap on these units. I sell Amana PTACs. You may be alittle low on gas. Check your air TD and that will tell you. The compressor may be overheating due to lack of cool gas to cool the comp. May need a service tech but get a free estimate first. Rus
Comments:
Jul 06, 2009
- Take a thermometer hold it in front of unit where the air pulls in record temp in about three minutes. Take the thermometer place it in the supply air or where the blows out hold for thrre minutes record temp. Subtract outlet from inlet and that is your temp difference. Most service techs dont like working on ptac unit. Just call aroung if they sell Amana Air conditioners they will work on yours. PTAC unit are not hard to work on Rus
Was this helpful?
Yes
No
Popular Solutions for GE Zoneline AZ55H07D Air
Questions and Unsolved Problems for GE Zoneline AZ55H07D Air
Do you recommend GE Zoneline AZ55H07D Air Conditioner?
Answer
Answer
I have a Ionic Pro Model No. CA-200B, and I am trying to find a repair/service place in my area that... (More)
Answer
GE zoneline heat pump/ AC unit wont blow any hot air? When you turn the switch to high heat and the... (More)
Answer
i have a 30 gig zone that what charging in my truck and my dog bit the wire in half ever since it... (More)
Answer
GE Zoneline HP PTAC A3B688DAALW1 WIRING DIAGRAM? Found a 6" L white wire with 1/4"F... (More)
Describe your Air Conditioners problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Air Conditioner Experts
Top Air Conditioner Repairmen
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
