Model no.420
Rror codes
If the printer's front panel displays a message Error XX, find the error code in this table and follow the instructions for resolving the problem. If problems persist, check the Xerox web site www2.tek.com/TekSMART/ or contact service.
Error
User Corrective Action
Error 01
Error 02
Error 03
Error 04
Error 05, 10, 11,12, and 13
Error 20
Error 21, 22, 30,and 32
Error 33
Error 40, 41, 42,and 43
Error 50, 51
110-Volt Fuser Part Number 016-1839-00
220-Volt Fuser Part Number 016-1840-00
Error 52
Error 53
Error 60
Error 61
Error 62
Error 63
Error 70, 71, and72
Error 73
Error 74
Error 80, 81, 82,83, and 84
Error 01p through
Error 47p
SOURCE: Xerox Copier Machine - Error U4
The fuser is not warming up.
On that machine under the web there is a thermal fuse on a white plastic mount, it has one screw through it.
It is most likely blown. Possibly caused by a jammed paper in the fuser.
That fusable link needs to be replaced.
SOURCE: my machine shows a U4 code
U4 code refers to a fuser heat failure, you'll probable find the fuser roll is stone cold .Possible cause is open circuit heater or overheat thermostat popped.Either way you will need to pull out the fuser unit and check continuity of the components
SOURCE: Xerox Workcentre Pro 123 error code 016-719
this is not a mechanical error but a software error.
It either doesn't recognise the format or program
as for the driver don't thinkit's the problem the HP can use PCL6
SOURCE: xerox c118 error
hi its a registration sensor error.. first u try to clean sensor.. again its not working better u replace a new sensor...
SOURCE: Xerox Work center Pro 423
The most common explanation for the error 'U4-2' in all the 'Xerox' machines is "Fuser warm up failure occurred". I am very sorry that such a problem has occured for you. It cannot be solved by you, if you are not a qualified technician and without proper tools.
Please do call the nearest service centre for a visit and they will probably solve it in a day. Remember, they need the service manual procedures for solving it properly.
Don't worry, it is a very common problem. But only authorised service people can help you in a good way.
Bye
Have a nice time.
