The convergence IC's probably need to be replaced. Unless you are savvy with electronics, I would not attempt to fix it. Call a professional. I would estimate a repair cost of aprox. 280.00 to 350.00.
Hope this helps,
Skyassoc
i have a mitsubishi vs- 45609 projection t.v. it will not come on... there is power at the outlet...
(More)
i have a mitsubishi vs- 45609 projection t.v. it will not come on... there is power at the outlet but when i plug in the tv and hit the ppwer button nothing happens.no lights no noise.nada.can you tell me whats wrong???
My mitsubishi 45609 will not work with the cable connected. White noise. It acts as if the tuner is...
(More)
My mitsubishi 45609 will not work with the cable connected. White noise. It acts as if the tuner is bad. The a/v inputs work fine but not the cable input. I checked the cable with another TV and set the input to cable. Are there any fuses that could be bad?
I work in the electronics industry, but always have schematics for what I work on. I pulled the...
(More)
I work in the electronics industry, but always have schematics for what I work on. I pulled the circuit boards out and found an area that I believe to be at least one of the problems. I have two parts, one is a capacitor that are charged and broken. I want to just replace the whole pcb. Who could I go through to do this?
