Cars & Trucks Logo
A
Anonymous Posted on Oct 08, 2014
I have a Chevrolet Silverado 2007 new body style saying that i have reduce engine power code p2138
My truck just started with this on the freeway. It just keeps going in and out with the reduce engine power by just turning it off and on. once it did not want to move at all even when i put the pedal to the floor
Charles Tucker
Level 3:
Master:
  • Chevrolet Master 460 Answers
  • Posted on Oct 09, 2014
Charles Tucker
Chevrolet Master
Level 3:
Master:
Answers
460
Questions
Helped
172693
Points
1205
The automotive trouble code P2138 throttle/pedal position sensor/switch D/E voltage correlation refers to a problem related to the throttle's ability to open and close properly. Replace (suggest) the sensor (black object) on the throttle body.
5 Related Answers
Anonymous
  • Posted on Aug 02, 2008
SOURCE: 2004 chevy silverado
need to reset oil life...look at manual
Anonymous
  • 50 Answers
  • Posted on Apr 01, 2009
SOURCE: headlight assembly
Hello streets54, my name is JShreader. Thank you for choosing fixya.com.
First, you have to remove the Upper Radiator Grille. Behind the Headlamp at the top of the Front Bumper, access the lower inside hidden Headlamp Bolt. Only loosen the Bolt. DO NOT REMOVE. Now remove the 2 Headlamp Screws, then the Hidden Screw...now the Headlamp Housing should come out. I uploaded the procedure in .pdf format. You can download it by clicking HERE. I hope this helps you. If you have any more questions or need any more diagrams, please don't hesisitate to ask...Thanks again, JShreader!
motor1258
Mike Butler
  • 6674 Answers
  • Posted on Jul 03, 2009
SOURCE: reduced engine power signal throwing out codes
There is a GM service bulletin on this particular item. basically covers both codes your getting.
#07-06-04-019A: Intermittent MIL/SES, DTC P2138 with Reduced Engine Power (Repair Instrument Panel (IP) to Body Harness Connector)
Models: 2005-2008 GM Passenger Cars and Light Duty Trucks (Including Saturn)
Anonymous
  • 1190 Answers
  • Posted on Jan 13, 2011
SOURCE: Getting on interstate when increasing
Hello, Check the wiring at the throttle body on the motor that drives the throttle plate. Wires can be broken inside the insulation or bad contact at the connector.
ZJLimited
ZJ Limited
  • 17989 Answers
  • Posted on Jan 20, 2011
SOURCE: i have a 2008 chevrolet
DTC P2138 - TPS/Pedal Position Sensor/Switch D/E Voltage Correlation
Check wires and harnesses connections first, then its possible that the sensor go to bad.
Keep us updated.
Testimonial: "thanks so much very helpful where can i get that sensor from"
04 chevy trailblazer Reduced engine power
You have a problem with the electronic throttle control . You need to have it checked for codes , could be a few different thing's Pt 1 2007 Chevy 2500HD Reduced Engine Power Warning Fault Code P1516... P2138 APPS Accelerator Pedal Position Sensor Fix 3 5L Chevrolet Impala Lot's of codes for this , Drive by Wire Function and diagnostics by Wells
Reduce power light on has no throttle and keeps giving throttle accuator cdes
2003 Silverado 2500HD REDUCED ENGINE POWER - Discussion on Topix
www.topix.com > Top Stories
Dec 28, 2009 - 20 posts - ‎12 authors I have replaced the throttle body, had the wires re-connected and .... The gauges all went wild and reduced engine power displayed on the dash. I looked it .... The truck just went to idle for no reason and it keeps happening. 2003 Chevy Trailblazer-CHECK ENGINE LIGHT AND ...
Dec 23, 2011
Reduced Engine Power message
Jul 29, 2008
2003 Chevrolet Silverado - Reduced Engine Power
Nov 3, 2007
Trailblazer - Reducted Engine Power
Aug 3, 2006
More results from www.topix.com
Reduced Engine Power Message Displayed on GM Vehicles
www.underhoodservice.com/tech-tip-reduced-engine-power-message-dis...
Dec 10, 2012 - Tech Tip: Reduced Engine Power Message Displayed on GM Vehicles ... Model year 2008-'10 vehicles must have the engine control module (ECM) reprogrammed ... Do not drop the electronic throttle control components.
2answers
I have a 2010 Chevy impala. Reduced engine power and check engine light also comes on but won't stay on. Codes are P2138 P2122 P0455
Hi Rosalee_IM,
The codes your vehicle is storing are for low voltage from your accelerator pedal position sensor and a gross evaporative emission leak. The code P2122 and P2138 are directing you to test the accelerator pedal position circuit and/ or sensor. This is the cause of the reduced power concern you are feeling.The P0455 is telling you there is a large leak in the evaporative emission system. The most common cause for this code is a loose or incorrectly installed gas cap.I hope this helps clarify the concerns you are experiencing. If you'd like more information on how to trouble shoot the problems,drop me a line. Please include the model Impala you have,(LS,LT or LTZ) and the engine size. I will do my best to get back to you as soon as possible.Thanks, Chuck
2003 CHEVROLET SILVERADO 2500 BACKFIRING?
check your timing belt or chain
11helpful
I have a p2138 code and when engine light comes on it starts losing power and you to shut off engine and restart and it will go for awhile and it will happen again. next day no problem
There is a GM Technical Service Bulletin (TSB) on this issue, below is a summary;
2005-2008 HUMMER H2
2006-2008 HUMMER H3
2005-2008 Saab 9-7X
Condition
Some customers may comment on an intermittent MIL/SES light Illuminated with a message center or an indicator that displays Reduced Engine Power. DTC P2138 - Accelerator Pedal Position (APP) Sensor 1-2 Correlation may be set. The voltage difference between APP sensor 1 and APP sensor 2 exceeds a predetermined value for more than a brief period. Refer to DTC P2138 in SI for further diagnostics.
Cause
On some vehicles, the IP to body harness connector, which carries the APP signal to the ECM/PCM, is located in the left hand kick panel area or inside the IP. Water intrusion into these areas could cause an electrical short in the APP circuits setting a P2138 code.
Correction
Note: Make sure that no add-on/aftermarket equipment is electrically connected to the APP signals or to the other ECM/PCM five volt reference or return lines. These can generate false P2138 and/or other ETC System DTCs. If there are other engine DTCs besides P2138, such as MAP sensor faults (i.e. P0107, P0108), resolve these first before attempting to diagnose P2138 DTCs.
Important: Refer to DTC P2138 in SI to confirm that the ETC pedal is operating correctly.
Locate the IP to body harness connector, which may be located in and around the left hand kick panel area or inside the IP. Check to see if there is a water leak into the area and repair as necessary. Use a water hose to determine the source of a water leak and effectiveness of repair. Some examples of potential water leaks are: A-pillar seals, sunroof drain lines (if so equipped) and windshield/cowl sealing. Finally, repair or replace the IP to body harness connector, making sure no corrosion or debris is left on or between the terminals.
1helpful
Why does my engine light come on occasionally with the reduced power sign
Condition:
Some customers may comment on an intermittent MIL/SES light Illuminated with a message center or an indicator that displays Reduced Engine Power. DTC P2138 - Accelerator Pedal Position (APP) Sensor 1-2 Correlation may be set. The voltage difference between APP sensor 1 and APP sensor 2 exceeds a predetermined value for more than 2 seconds. Refer to DTC P2138 in SI for further diagnostics.
Cause:
On some vehicles, the IP to body harness connector, which carries the APP signal to the ECM/PCM, is located in the left hand kick panel area and if the kick panel is not sealed properly, water enters and causes a short in the APP circuits setting a P2138 code.
Correction:
Important: Do Not replace the accelerator pedal assembly.
Locate the IP to body harness connector, which may be located in and around the left hand kick panel area. Check to see if there is a water leak into the area and repair as necessary.
4helpful
CHECK ENGINE LIGHT ON AND REDUCED POWER LIGHT ON, I HAVE HAD IT SCANNED AND THE CODE P2138 COMES UP, WHAT CAN I DO? MY CAR IS A 2004 TRAILBLAZER
Replace your throttle position sensor, runs about $60.00 sit on throttle body has a round connector with three wires going o it.
17helpful
2answers
Reduced engine power signal throwing out codes p1125 and p2138. what do i do to fix the problem?
Top Chevrolet Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you a Chevrolet Expert? Answer questions, earn points and help others
