Question about DeLonghi CF210 Portable Air Conditioner
Need AC for Server Room
My company's server room does not have a window (or outside wall). I've been looking at the portable units but they all seem to need close access to a window. Can you recommend a solution. For example, are there longer hoses available for intake and exhaust? If so, do they negatively impact how well the unit cools?
    Problem Solver:
  • 6 Answers
I find it amazing that in this day and age IT manager will still scrimp on there server room environmental systems! It must not be that critical! Anyways you'll be better off with a split type unit correctly sized for your server room. Toshiba now have small units that can pump up to 50 meters away if needed. the key is to have it correctly sized!
Posted on Nov 14, 2007
Remove exhaust hose
U need that hose to direct the warm air outside the area to be cooled. If you remove it, the hot exhaust will stay in the room being cooled and negate the cold air being directed into the room.
That is why regular room AC units are mounted on window sill. Cold air in, hot air out.
Oct 08, 2015 | Haier Commercial Cool 8,000 BTU Portable...
Not cooling anywhere near what it claims.
Try to turn OFF the Music Mode Only.
Turning on Music Only Mode will disable voice and data calls..
Sep 07, 2008 | Soleus LX-140 Portable Air Conditioner
Why is my appartment getting cooler ???
An air conditioner really just moves heat from one place to another. Normally there is an inside unit and an outside unit, or in the case of a window unit, half is inside the room and half outside the window. In either case, it takes the heat from in the room and moves it outside. This portable unit apparently takes the heat from one room and dumps it into another. There is no magic heat elimination - it has to go somewhere.
Jul 01, 2014 | Simplicity 6,000 BTU Portable Air...
We do not have a window in the room this need to be installed in. Does the window installation kit allow us to install the pipe that goes outside through our exterior wall of the house? Like a dryer vent...
I think you probably could. As most manufacturers of portable AC units allow for this. It's what called a semi -permanent installation . The dryer duct idea will work if the shaft part of the dryer duct is the same diameter as the window mount duct and the shaft of the dryer duct is long enough to go thru the wall and leave enough for the AC Exhaust Duct to hook to. Be sure that the flap door of the dryer duct moves freely and will not get stuck in the closed position. That could be a big problem if it does.
Keep in mind, you will not be able to add any length the AC duct hose. It must remain the same.
Hope this helped answer your question and things for choosing FixYa.
Aug 01, 2011 | Sovereign Royal 9000 BTU Portable Air ...
Not cooling 110 sq ft room
The smallest retail AC unit will cool down a 110 sqft room if...
1. It is installed in a way as to dump heat outside... 2. There is actually cool air coming out of the AC (it is working)... 3. The windows and doors are tightly closed... 4. There are no major drafty leak issues (i.e. hole in a wall)... 5. You're not adding substantial heat energy into the room (such as having 10 sweaty fat men eating food while watching Super Bowl on a 56" LCD TV)... 6. The room has at least minimum insulation (the walls are not just plywood)... Seriously, if HEAT is leaving the room by way of the AC, the room temperature HAS to decrease, unless HEAT is being added back into the room in some way. This is basically the 1st law of thermodynamics.
Jul 24, 2011 | Heating & Cooling
Where can I get a manual for my Emerson Quiet Cool Room Air Conditioner? Not sure the model, but these #s were on outside of box: 10DC93 784040B OE21M N14421, is on a little sticker on the right...
Let see if I can help. The numbers don't come up so we'll just try your information.
Exhaust - should be closed when using for Air Conditioning
Energy savings turns the fan off with the compressor when set for Air Conditioning
Fan Only means just that (no Air Conditioning)
Fan speeds Quite same as low, Norm same as medium, Super same as High
Temp settings, what the thermostat senses before cycling compressor.
Jul 04, 2011 | Emerson Quiet Kool 10GV13 Air Conditioner
I want to buy portable air conditioner, but the buyer said that i need put the exhaust tube near a window open to expel hot air, in my room not have windows
You do have to use the exhaust tube, would need to put a hole in your wall. Also, these units really generate a lot of heat. We tried one, it almost seems as if it actually makes the room hotter! You would be better off buying a small regular unit, constructing a hole in the wall to the outside.
If you absolutely cannot do the hole, you could get an extension to the exhaust tubing and maybe use a window in another room?
Apr 04, 2011 | Heating & Cooling
Royal Sovereign not keeping the room cool.
electronics give off alot of heat you need larger unit
May 19, 2009 | Royal Sovereign ARP-4009 Portable Air...
Need to powerup PowerEdge with out hitting the power Button!
ahhh ok, well in the bios of some machines their is an option to schedule a wakeup time for the PC, and you could also enable Wake On Lan and then wake up the PC remotely from a computer outside of the server room?
Feb 20, 2009 | Dell PowerEdge 1600SC Server
Delonghi AC problem
suspect a faulty running capacitor.
Apr 24, 2008 | DeLonghi Pinguino PACL90 Portable Air...
DeLonghi CF210 Portable Air Conditioner Logo
107 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
