Question about Microwave Ovens
I exploded an egg cooker in my Jenn air microwave M167 and top plastic cover cracked. I can see part of a round disc like thing that broke off. The microwwave still works, but is slower and seems to h
If I need to replace, how do I get it out of the builtin cabinet? It's above my built in oven. I exploded an egg cooker in my Jenn air microwave M167 and top plastic cover cracked. I can see part of a round disc like thing that broke off. The microwwave still works, but is slower and seems to heat unevenly. Is it worth repairing?
    Top Expert:
  • Microwave Ovens Master
  • 51,937 Answers
You have to evaluate cost to repair vs. replacement.
Posted on Nov 13, 2017
5 Suggested Answers
SOURCE:
MicrowaveSvc
  • 9156 Answers
SOURCE: Broken Handle on Jenn-Air Model M406 Under Cabninet Microwave
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
Posted on Nov 27, 2008
breddi2
  • 126 Answers
SOURCE: plastic melted inside oven, dripping from ceiling Kenmore 721
The round peice in top of unit is a cover for the stirrer wich moves waves around for even cooking. The reason for it melting is almost certainly there is not enough paint in cavity and waves are shorting out to metal.CALL the manufacturer and depending on age of unit they may replace it free
Posted on Apr 22, 2009
  • 8909 Answers
SOURCE: i have jenn-air microwave oven
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
Make sure the !!!!capacitor is discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 on high resistance range for short circuit, the capacitor can fail and go short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Posted on Dec 28, 2010
  • 910 Answers
SOURCE: Jenn Air Microwave M167 Replacement Oven
I would expect it to be connected to the same electrical circuit as your convection oven so if there are no breakers that have tripped in your electric panel and the convection oven still works then their are 2 options.
1) The Microwave is connected via a Fused Spur (or possibly a Plug direct into a Socket) and Fuse has blown. This could be located somewhere behind the Microwave or in a cupboard to the side or above.
2) The Internal Fuse on the Microwave has blown possibly due to a power surge or an internal component that's failed.
First thing to do would be to check for the Fused Spur or Socket located somewhere around the Microwave. If you can't find one then you would need to remove the Microwave and see where/how it's power supply is connected.
If you could look at this and then let me know your findings we can take the investigation from their.
Posted on Jul 13, 2011
Jennair combo micro wall oven 30" replace microwave?
When a microwave is dead, the most common causes are a blown fuse, or a blown thermostat / thermal cutout / TCO on the magnetron or on top of the oven cavity.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Accessing the oven cavity thermostat for testing and possible replacement will require you to remove the oven from the wall and take off the outer cover.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download Jenn-Air (Whirlpool) owner's manuals and installation instructions here.
Dec 25, 2012 | Jenn-Air JMC8130DD Microwave Oven
I have jenn-air microwave oven model m167. Unit will come on and all programming works to heat food. Oven acts as if it is heating food,however it does not cook or heat food items. Any help with...
Hope that helps.
Dec 28, 2010 | Jenn-Air JMC7000 Microwave Oven
The microwave guide silver cover sparked and arced to frame. Called service company -- came out took the part and went out of business. Can you tell me where to get this cover (plastic rivets still in...
That would be the waveguide cover or stirrer cover.
You order parts and find helpful exploded view diagrams here.
I'd recommend that your bookmark this link to your favorites.
You can download owner's manuals and installation instructions for several brands (including Amana, Jenn-Air, Kitchenaid, Litton, Maytag, Roper, Tappan, Thermador and Whirlpool) here.
Jan 29, 2010 | Microwave Ovens
Jenn Air Microwave model JMC7010 turntable has stopped working. It will intermittenly turn, like a belt drive is slipping underneath. How could I fix this?
The turntable system typically consists of the motor, the coupler, the turntable support with rollers, and the tray.
Here is a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover.
In some brands, you have to cut the motor cover off with snips, then use a screw when reassembling it.
You can find links to helpful exploded view diagrams and part ordering help here. I'd recommend that your bookmark this link to your favorites.
Nov 27, 2009 | Jenn-Air JMC7000 Microwave Oven
Can anyone get a hold of the Jenn-Air Microwave M170W Button to open the door (Part# 56001009)Mine cracked and the part has been discontinued. Thank you.
Same thing happened to me. I couldn't find a replacement part, but I was able to make a fairly easy functional repair. If you take off the microwave cover, you can reach the back side of the control panel where the door release button is located. With a screwdriver or your finger, you press down on the top attachment tab (it's the swivel point that holds the button in place) with just enough pressure to remove the button. You'll have to do something similar to remove the other half of the broken button. If the two pieces of the button fit neatly together, then you can epoxy a piece of flat metal or rigid plastic to the back side of the button in order to join the two halves. Be sure to clamp the two halves of the button tightly together while the adhesive sets to get a tight fit and minimize the crack line. Let it cure, then replace in the microwave. It's not cosmetically perfect because there is still a hairline crack in the button, but it's not that visible and the button works well. I can't say yet how long this repair will hold up yet. I suppose that will depend on the quality of the bond you achieve when repairing the button. Good luck.
Jun 23, 2009 | Jenn-Air M170 Microwave Oven
Egg cookers
I found the instructions
Sprinkle a few grains of salt on bottom of egg cooker. (Salt attracts microwaves and is necessary to help cook bottom of egg)
Break egg into egg cooker.
One egg in micro at a time.
Will fork piece yolk and white to bottom of cooker, three times. _ This is very important.
Line up notches on egg cooker lid and cup then twist until locked
Micro on High for 30 seconds
Let stand 10 seconds
If bottom of egg is not cooked turn egg over with a spoon and microwave on high for another 10 to 20 second or until cooked.
Dec 16, 2008 | Microwave Ovens
Nov 24, 2008 | Microwave Ovens
Jenn-Air JMC8100- Microwave
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Aug 05, 2008 | Jenn-Air JMC8100 Microwave Oven
Damage to samll rectangular material inside microwave
Well, I have just spoken with a reputable, but now retired, appliance repairman, he advised that this small rectangular cover on the upper interior of the microwave is a MICA Insulator Shield - of which one may be able to purchase just the shield. At this time, I do not know if any appliance parts places have this MICA Insulator Shield available for purchase. But apparently you can purchase a pice just slightly larger and cut the right size for replacement.
If the old one is burnt at all, or has a hole or crack in it - Do Not Use the Microwave.... as it will begin to arc and likely through out the breaker and/or fry the magnatron.
Mar 05, 2008 | Danby DMW1153 Microwave Oven
Microwave Ovens Logo
62 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
