Question about Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television
Sony 60" HDTV Plasma WEGA....Picture Problem
I had this TV for about 2 years. There seems to be a problem now with the picture, it looks sort of faint yellowish green, even adjustments couldn't fix the problem, the picture just lost its true color it had before, it looks really dull... I have a 50" model and the green is gone. I push the Hue up all the way and improves picture but still no green.
  • 934 Answers
Re: Sony 60" HDTV Plasma WEGA....Picture Problem
My guess is that you're not missing the color it just appears muted... That problem is a common one in both the 50 and 60 inch models. And if you change video mode with nothing hooked up you'll see a faint color where none should be...
That's simply dust in the optical block on one of either the red, blue or green lcd panel. Wipe it down with a non-linting cloth and a "light" amount of windex and you're back in business...
But check it out by switchin through the video modes with nothing hooked up.. The faint color you see if the lcd panel that's having the most problem and the one that's muting your green.
Posted on Nov 11, 2007
0 characters
3 Points
Projection tv is about 7 years old. I am getting no picture. when I turn it on the red light just blinks and no picture no sound. the tv just will not power up. I unplugged to reboot. did not work. Is...
If this is a Sony Grand Wega, call Sony, complain, and Sony will give you an option to get a brand new for a very small amount of money instead of fixing the one you have due a class action, if you qualify.
Apr 13, 2011 | Sony Grand WEGA KDF-60XS955 60" Rear...
No Video/Sound,POwr Gren LiTE Blinks 4Ever, SONY WEGA KDF-55WF655
Please check lamp in tv as pop sound seems broken lamp.
Did you replaced lamp in last 2-3 years in tv? If not, then its lamp that got broken and tv needs new lamp.
Lamp replacement procedure is written in user manual and its easy, please buy Sony original lamp for good picture in tv.
Apr 25, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
I have the sony wega 60 lcd tv, it turns on ok then shuts off
How long have you had the set? If its been at least two years then its time for a new lamp.
you can email me at
if you need futher assistance. I believe your lamp is faulty...
Sep 26, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Sony 42in- No picture or sound
You need to replace the bulb...very easy. You can do it yourself.
Dec 23, 2008 | Sony Grand WEGA KDF-60WF655 60" Rear...
Picture quality is bad
it sounds like your green gun is faulty or a faulty colour drive, a transistor on the back of your CRT board also check for dry solder joints.
Dec 04, 2008 | Sony Grand WEGA KDF-60XS955 60" Rear...
Faint red lines in a curved arch like pattern
Is there a cheaper solution? $600 sounds like you just throw it away to me...
Aug 02, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
This seems to be common problem with Sony projection tv. I have the KDF-E50A10 that lasted only 2 years. It's sitting in a corner now until I figure out what to do with it. I am not going to spend another grand to repair it!! Never Sony again.
Jun 16, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television Logo
139 people viewed this question
Top Sony Projection Televisions Experts
Steve Sweetleaf
Steve Sweetleaf
Jason Harris
Jason Harris
Are you a Sony Projection Television Expert? Answer questions, earn points and help others
