Question about West Bend Coffee Makers & Espresso Machines
Replacement parts for a Lifetime West Bend percolator
I own a Lifetime Flavo -perk (6-10 cups) made by West Bend on 1969 Cat No 7238. The pot is in excellent condition. It does not work because all the electric parts are damaged. Is there any electric replacement kit for this percolator? Where can I find it if available?
Re: Replacement parts for a Lifetime West Bend percolator
Have you contacted Lifetime? If you google them in Niagara Falls Canada, you'll get the phone number for their Canadian warehouse...they're great and can give you the USA location for parts or help you. Too bad you don't live in could walk in and get it sorted immediately. I have one of these percolators and use it it.
Posted on Oct 04, 2010
0 characters
3 Points
Where can I replacement filters for a 100 cup West Bend coffee maker?
The West Bend Large Capacity Coffemakers do not use replacement filters. The manual for the West Bend 33600 Large Coffee Urn is available here:
Use an electric perk or regular grind coffee in the percolator basket rather than a 'drip' or finely ground coffee that would require a filter.
If you require a new basket, please see the West Bend on-line replacement part site here:
Mar 19, 2011 | West Bend 33600 Coffee Maker
I am looking for a replacement black handle for a 100 cup West Bend coffee percolator. One is broken and hence does not clap the lid properly
if you can find the model number for your product you should be able to order a replacement handle from Ihe following site:
Sorry someone has not responded sooner.
Jan 07, 2011 | West Bend PERCOLATOR
Coffee maker heats but does not ''perk''
The well at the bottom of the pot where the tube fits in can get coated with mineral deposits from hard water, and this causes the problem you're having.Some brands of coffee makers come with a cleaning tool for this. It's a flat metal piece that fits the well, and you use it to work a piece of steel wool (plain, not a soap pad!) back and forth to scrape off the buildup. If you don't have the tool, you can just cram a wad of steel wool into the well and twist it around by hand. It also helps to pour in Lime-Away (or a similar kind of cleaner) to fill the well and cover the bottom. Let it soak for a while, use the steel wool (wear rubber gloves to save your hands), and finish up with a thorough washing.
Nov 22, 2008 | West Bend 13500 Coffee Maker
Basket and perk tube
Sure is
see if you can locate the model somewhere on in it
Try this to order all of your part needs !
Mar 01, 2008 | West Bend 13500 Coffee Maker
West Bend 36 cup coffee maker amounts
It's a percolator. Use about 1 heaping teaspoon of coffee per cup. Each coffee pot is different. You will have to adjust the amount of coffee for what you like.
Dec 03, 2007 | West Bend (58036) 36-Cup Coffee Maker
Coffee Makers & Espresso Machines Logo
473 people viewed this question
Top West Bend Coffee Makers & Espresso Machines Experts
Ray Murphy
Are you a West Bend Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
