Question about Sharp AL 1631 Copier
No copies a P appears in the screen; and I cannot get copies. There is plenty of paper; toner is fine; etc. Help!
Re: No copies - Sharp AL 1631 Copier Printers & Copiers
Add paper to the bypass tray
Posted on Nov 13, 2007
  • 69 Answers
Re: No copies
Hi imjules_09.have you tried reset it in the program?if you print then the paper came out with out a copy you have a problem with the drum unit or tansfer unit.p is not a error code so try to close all door the copier has first the bypass tray the front door and the output tray check if there is a small piece of paper still in side.but first turn the machine off for 5 seconds then turn it on again.then go to the program to reset it.
Posted on Nov 12, 2007
0 characters
3 Points
Mysterious fluctuation in quality of copies.
fuser drum is bad. photocopier use electricity to transfer the toner to the paper, then it is heat fused to paper. it appears that the problem is occurring around the time that the toner is attracted to the paper.
Mar 07, 2014 | Canon PC-940 Black and White Copier
F-28-1 curently appears on my screen
F 28-01 High voltage power supply abnormality.
Ihe charging ON/OFF operation has been performed five consecutive times since the charging trouble detection signal was detected at start of charging.If there is a paper in copying process when this jam occurs,the machine stops after completion of copied paper ejection.Verify the charge wire,change and the holders.Check the high voltage unit.
F - 28 -02 Toner transfer wire malfunction
F - 28 -03 Toner separation wire.malfunction
Feb 11, 2013 | Konica Minolta Konica 7020 7022 7025 7030...
Canon NP4050 putting out blank pages
The NP 4050 has been known for given blank copies... Is the developing unit locked in place... There is a Grey or blue lever inside the front door to the right... It is under the toner hopper. It's been along time... I believe the lever should be clicked to the right and up. Also there is a locking screw that holds it in place, Most times that screw is missing and the unit falls away from the drum unit and you get blank copies and the front door will close.. Good Luck
May 01, 2010 | Printers & Copiers
Copy coming out blank
Normally a blank copy is caused by the image not being transfered from the drum to the copy paper. Which indicates a problem with the transfer step of the process, check for a bad transfer roller or a bad transfer belt. If this is not very obvious, run a copy and try to turn the machine off or open the front cover during the copy process when the copy paper is about half way under the drum and check for a toner image on the drum. If there is no toner image on the drum you may have a developer problem, broken drive gears etc. But if there is a toner image on the drum but no image on the paper then it is a transfer issue.
Sep 15, 2009 | Printers & Copiers
What does ap mean
"AP" stands for Agitation in Process", it appears in the copy quantity display when toner is being replenished inside of the copier. Wait a few minutes..this happens after continuously copying for long periods, or copying dense things like photos. Sometimes it will occur after running the machine when it is out of toner. replace toner and turn on/off a few times to "agitate toner. Don't worry about the scan lamp being lit while this is happening, it will go out.
Hope this helps
Sep 08, 2009 | Copystar CS-1810 Copier
Brother HL2040 - Shading of toner all over my page when I print
The drum is a very sensitive part. Should not touch with bare hand, expose to light for long, etc. With what did you clean,it.
May 19, 2009 | Brother HL-2040 Laser Printer
My Brother HL 5240 has Status toner, drum and paper lights on, I bought it on 4/30/08, new toner, plenty of paper, it showed on computer: printer is off line, but it was connected with computer. Really...
The drum light will flash on my brother HL-5240 Laser Printer when printing but it continues to print just fine. Does this mean the drum needs to be replaced?
Aug 07, 2008 | Printers & Copiers
Canon6050 toner recycling
I have glanced at and passed by your question several times, and finally cannot resist the urge to answer. Canon copiers are unique in the fact that they are " monocomponent". This probably means nothing to the average person. But suffice it to say,the"waste toner" you speak of is primarily drum polish and paper dust, neither of which is very good at producing a decent copy. In fact, ANY percentage of waste toner introduced into the Canon copy process is a recipe for disaster. I primarily say this because at some point you will have to replace the development unit (or have some serious service) and probably replace the drum ($1000) if you continue. I am not a Canon employee but have worked on Canon equipment for over 20 years. I merely wish to help. I would be hard pressed to see how you can save enough money up front to cover the back end costs.
Apr 07, 2008 | Canon NP 6050 Copier
Brother HL-2040 All LEDs stay lit and the printer no longer works
Turn it on and when all the LEDs light up, THEN press the Go button. One or more LEDs will stay lit and the others will be off. Look in the user manual (you can find it online at the Brothers site if you don't have one). There is a chart in the Troubleshooting section that will tell you what problem your particluar combination of "lit" buttons indicates. It may suggest fixes, or depending on the problem, tell you to see a repair person.
Nov 19, 2007 | Brother HL-2040 Laser Printer
Sharp AL 1631 Copier Logo
Top Sharp Printers & Copiers Experts
George Mclaughlin
Vito Suglio
Level 1 Expert
Are you a Sharp Printer and Copier Expert? Answer questions, earn points and help others
