Cars & Trucks Logo
B
Brian Laubscher Posted on Oct 08, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a 2006 GMC Yukon Denali XL that has a parasitic drain. The drain is approximately 3A. When the radio 15A fuse is pulled it drops 1.2A and when the 30A Radio Amp fuse is pulled it drops another
I have a 2006 GMC Yukon Denali XL that has a parasitic drain. The drain is approximately 3A. When the radio 15A fuse is pulled it drops 1.2A and when the 30A Radio Amp fuse is pulled it drops another 1.2A. I disconnect the radio, amp, CD player and rear entertainment system and it still draws 3A unless the fuses are pulled. Any ideas?
  • Mike Christianson
    Mike Christianson Apr 25, 2015
    Did you ever figure this out? 2005 yukon Denali with same symptoms. 3 amp draw. Remove radio fuse goes to 1.5. Remove amp fuse goes to near 0.
Denis Houle
Level 3:
  • GMC Master 1,414 Answers
  • Posted on Oct 12, 2014
Denis Houle
GMC Master
Level 3:
Answers
1414
Questions
0
Helped
498578
Points
4096
Pull fuses or relay until current drop to 50mA and less.
5 Related Answers
Anonymous
  • Posted on Oct 20, 2008
SOURCE: location of fuse box/panel for 2004 yukon denali xl
There are 2 fuse panels in the Denali.
One is a panel on the drivers side, its on the dash but facing the door.
The ohter is under the dash and above the pedals, this one is much tougher to access.
Your Owner's Manual should tell you where the fuses are that you need to access.
Anonymous
  • 426 Answers
  • Posted on Dec 29, 2008
SOURCE: 2001 GMC Yukon Denali XL -intermittent dead battery
The wiper should not move regardless of battery change as the wiper switch should have isolated it.It seems to be the only ,as you say,strange thing and would be inclined to believe that that is the probable cause of your fault.Do like your testing method and hope you track the fault down.Good luck and happy new year.
Anonymous
  • Posted on Jul 20, 2009
SOURCE: Can't Identify Fuse for Radio
The "Audio" fuse is in the engine compartment fuse box
Anonymous
  • Posted on Dec 19, 2009
SOURCE: 2007 gmc yukon navigation problems
Did you ever figure out this problem that you were having? I have an 07 Yukon and it sounds like the navigation is still on too when I shut it off. I haven't had the battery go dead on me yet, but I'm hoping that it doesn't happen too as I just purchased it. Let me know if you found anything out, I would greatly appreciate it!
Anonymous
  • 1015 Answers
  • Posted on Dec 29, 2009
SOURCE: 2006 GMC Yukon Denali XL Rear Hatch & Glass locks not working
Could be the latch mechanism for the door is sticking. You could try using some white grease on the latch and the contact where the latch hooks to. You can purchase the grease from most auto parts stores. You will not need to use alot. Just apply a small amount to the mechanisim and then work it in using the manual handle. Then open and close the door several times to feel the "action". Then apply a little more and repeat. This should loosen the latch and get it working again. Also make sure that none of the tension springs have come loose on the latch. And check the seal around the door and make sure it is not pinched and has a proper fit.
Does anyone have pinout diagram E38
You don't say a pinout of WHAT?
https://www.google.com/search?q=pinout+diagram+E38
Denali Radio?
GMC Yukon Denali 2014 - SYSTEM WIRING DIAGRAMS
https://portal-diagnostov.com > 2020/04/13 > radio-gm...
Apr 13, 2020 - RADIO - GMC Yukon Denali 2014 - SYSTEM WIRING DIAGRAMS Dual DVD Headrest Wiring Diagram. Get Access all wiring diagrams car. Radio Wiring ...
GMC Yukon XL pinouts - PinoutGuide.com
https://pinoutguide.com > dev > GMC > Yukon+XL
Here are pinouts for GMC Yukon XL devices. ... There are 6 pinouts found for GMC Yukon XL . The pinout (pin-out) ... The pin outs diagrams are listed below.
I need help with a battery drain on a 2002 GMC Yukon Denali XL
As odd as this sounds, I would take it to "Car Toys" and have them take a look at the stereo wiring.
4helpful
2answers
Where is the cam shaft location sensor located on a 2005 gmc yukon
camshaft sensor located above crankshaft pulley, the camshaft sensor mounted on the front timing cover above the crankshaft pulley.
2answers
2003 GMC Yukon Denali My passenger side windows, locks, and mirror are not working...I am sure its a fuse but is unsure of the fuse location.
How to fix the steering wheel options on my steering wheel, for instance the volume for radio, onstar, etc? I have a '03 gmc Yukon denali xl
2008 GMC Yukon Denali XL. Just turned on the car and no audio
This is an electronics issue.
See all the fuses.
Cheers.
1helpful
Fan blower stopped working on my 2006 yukon denali xl
check fuse,blower motor relay and blower resister(mounted in blower box) and blower motor
1helpful
3answers
2002-2006 Denali front bumper fit on a 2001-2006 Yukon
Yup - you may need to get the grilles and such as well...
Top GMC Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a GMC Expert? Answer questions, earn points and help others
