Changing the vid
I have a dell 5150 that originally had a 3.0 p4 and someone changed it to a 2.4 p4. i bought a 3.2 p4 and the system will not power up. then vid on the 2 processors is do i chane it
  • 163 Answers
Dells 5150's are a problem and If they installed a 2.4 on this model theres a warpage issue usually.. (Dont ask).. Its complicated to say the least... Run on the 2.4 and reinstall the video driver for the actual unit.. (Did you ever see a "This unit does not support this CPU and may run" Blah, blah, blah. error on Boot ?? Thats why.. Good luck!
Posted on Feb 15, 2008
I am trying to upgrade my PE650 from a Celeron CPU to a P4 2.8GHz. Once I change the CPU the server will not run the BIOS. I just get a blank screen with all the fans running. Do I need to reset the...
First of all, open your case with the power unplugged and check to make sure you plugged in every part of the motherboard to the power supply. Look for white plugs.
If that doesn't work, try this:
1. Go to this website and scroll down to Figure 5-2.
2. While the computer is off and unplugged, use the picture as a reference and move the jumper on your motherboard to NVRAM_CLR.
3. Plug in your computer and boot it up. Wait at least 15 seconds then turn off the computer and unplug it.
4. Change the Jumper back to it's original position on the motherboard.
5. Plug in the computer and run the BIOS
Thanks, Rodrick
Apr 06, 2011 | Dell Poweredge 650 - P4 3.0GHZ, 1GB/40GB...
I have a Dell Dimension 5150 with a P4 3.0GHz and 3GB DDR2 Ram. About a week ago it started shutting down...cold. Not a Windows shutdown. It is like someone unplugs the power. It will then start booting...
Syptoms u have identifies are most probably linked to registry errors on ur computer it is wise to run? a registry repair scan with reginout? registry cleaner....
Aug 30, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
I have a dell 5150, OWG261 motherboard can I upgrade the processor from a P4 to an Intel Q9550 Core 2 Quad Proccessor - 2.83 GHz,12MB L2 Cache,1333MHz FSB,Socket LGA775,45 nm. with a 64 bit OS and 650...
Dell computers are proprietary. All upgrades are from Dell. At one time they offered an upgrade plan. Go to and check upgrades for your system.
Dec 07, 2009 | Intel Computers & Internet
Need a reboot disk
Does it have a Microsoft sticker on the case giving you a serial number and product type: 2000, XP Home , XP Pro etc
If it has one then you need to find a buddy with a copy of that software and hope that it is compatible with the version you have on your system.
If not then it is off to the shop for a fresh copy
Jun 02, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell dimension 5150 won't start
See solution in
Dec 20, 2008 | Dell Dimension 5150 (DIM515MIN) PC Desktop
My dell wouldnt post,
It sounds like the motherboard is damaged. Did you try to start with a boot cd? Or will it just not get to the bios setup screen?
Nov 28, 2008 | Dell Dimension 3000® Pentium® 4...
Asus P4T-M version 1.05 Not Posting?
Hi ed, that 4-Pin ATX_12 connector near the CPU is for powering the CPU. Suggest you change PSU's. Though I'd agree there are some boards that have the 4-Pin connector & it's not used. Those boards usually have a 24 pin main connector & lower voltage CPU's Please check here at Asus web site for P4T-M.
Related FAQ's P4T-M
I'm sure your P4T-M will boot after connecting the ATXPWR, ATX12V. As you noted, it would be nice if you could test the memory. When you get display you can test your memory for free by downloading a mem test program at.
Enjoy the weekend Ed.
Mar 20, 2008 | Computers & Internet
Change Motherboard For Dell Dimension 5150
If you replace with the same motherboard that's in already, that would be easiest for you.
But if you use a different one, you'll have to re-activate Windows, and download and install new device drivers.
Jan 09, 2008 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Can't charge battery or run off AC
You may have a problem in the DC charge circuitry. These parts are located on the moatherboard directly and can't be bought separately and repaired. You must send your Dell to a specialised service to have it fixed by them. Sorry, I can't see no other way for this problem to be solved.
Jan 20, 2007 | Dell Inspiron 5150 Notebook
Computers & Internet Logo
50 people viewed this question
David Payne
David Payne
