Home | Eureka | Smartvac 4870 Bagged Upright Vacuum | I have a Eureka The Bos...
Eureka Smartvac 4870 Bagged Upright Vacuum
Problem for Eureka Smartvac 4870 Bagged Upright Vacuum
I have a Eureka The Boss Smartvac. I was
By achemgirl on Jul 04, 2009
I have a Eureka The Boss Smartvac. I was vacuuming and it just went off. It was on one second and then off the next. I changed the bag thinking it was full but it didn't go back on. What's happening?
Solution #1
posted on Sep 07, 2009
Not Rated)
2poorcars
Rank: Apprentice
Rating: 0%, 0 votes
If you also notice on the bottom left corner of the vacuum standing behind it you will see a small warning telling you about this and to let the system cool for 30 minutes prior to turning it back on. Make sure you clear everything during this time.
Was this helpful?
Yes
No
Solution #2
posted on Sep 02, 2009
Not Rated)
e_dubsak
Rank: Apprentice
Rating: 0%, 0 votes
it overheated, just have to wait a few minutes, maybe change bag and have a look at filter in bottom of chamber where bag is located, clean it if its really dirty. lack of flow will cause the vacuum to overheat.
Was this helpful?
Yes
No
Popular Solutions for Eureka Smartvac 4870 Bagged
Questions and Unsolved Problems for Eureka Smartvac 4870 Bagged
Do you recommend Eureka Smartvac 4870 Bagged Upright Vacuum?
Answer
Answer
replacing motor in 4870, replacement motor slightly different, need wiring diagram......replacement... (More)
Answer
when putting the dial on carpet, the beater won't start. why???
Answer
brush does not turn and culprit seems to be that the barefloor /carpet switch will not stay in the... (More)
Answer
Mine spits stuff out the back and has since I bought it, only a few months ago. I can't tell if it... (More)
Answer
I removed the two star screws that allow me to pull the bottom of the switch panel away form the... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Eureka Smartvac 4870 Bagged...:
Top Vacuum Experts
Rank: Guru Guru
Solutions: 1303
Experience: 15 years field experience and 5 years navy training
Ask Me
Find more Vacuum Experts
Top Vacuum Repair
(877) 822-8227
When you browse our large selection by vacuum...
Vacuum Cleaner Shop
(502) 348-4900
Authorized Dyson and Miele Service center. Work...
VACUUM SOLUTIONS
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
