Question about JVC DR-MH30S DVD Recorder
JVC DR-MH50S My DVD HDD Recorder is telling me it is Loading and has a blue light flashing. This happended after a power cut.
  • 1 more comment
  • pigreco Nov 15, 2007
    yes
  • Carolus Dec 15, 2007
    I have made DVDs both analog and digital with the included burner.
    They play fine on the equipment.
    But when I try to play them on my laptop HP pavillion dv9000 my laptop doesn't recognice the DVDs.
    Do i need any special codec or is there anything else I can do?
  • Anonymous Dec 26, 2007
    Yes, DR-MH50S - same blue flashing loading display error. Have sent it to a JVC repair centre. 1st they told me it was a power problem & would be about £90 to fix. They made the repair but the unit was still showing the same fault. Waiting for the new diagnosis & estimate. Be a shame if its too expensive, was my favourite gaget & the similar products out there dont seem to have all the specs this has even after 2 years. Wont buy JVC again if there products only last this long.
Like Guest. I sent my DR-MH50S to a repairer recommended by JVC and paid about the same amount. When I got it back, it was showing the same symptoms and so took it back again. I am still waiting on the outcome. I will keep you posted!
I do not think there is a reset button on this player.
Irnbru
Falkirk
Posted on Jan 14, 2008
Just had the 2nd diagnosis for the error - "digital PCB" at a cost of £252 - BONKERS! Have e-mailed JVC to see if they can make the cost of the repair reasonable, got a positive reply they want me to send my proof of purchase, serial no etc. & they'll consider dropping the cost significantly. On top of that just found same model on ebay, ex display £130. baught it, was prepaired to pay upto same for the repair - gunna swap HDD for mine when it arrives, the stuff on there was the main reason i wanted it repaired. Still gunna try to get mine fixed for nowt though through JVC! May as well try for nothing!
Posted on Jan 12, 2008
Loading keeps blinking Nothing works anymore. even power of no longer works
Check for dried up electrolytic capacitors on the DC-DC converter C5318, C5340, etc.
Nov 13, 2009 | JVC DR-MH30S DVD Recorder
LOADING LIGHT KEEPS FLAshing
If 'Loading' flashes for more than one minute, try a reset by unplugging from its power source for 10 seconds than plug it back in and turn it on.
More likely this recorder needs to be serviced.You should contact JVC this issue usually qualifies for a free service program, which means JVC will flip the bill on repairing it if it is shipped to JVC's Service factory and their techs determine it qualifies.
Oct 04, 2009 | JVC DR-MV1S DVD Recorder/VCR
JVC DR-MH30 keeps flashing ''loading'' after recent power cut
Measure the 5V line on the DVD drive,if to low replace the bad caps in power supply.There is an 22 microfarad elco you can upgarde to 47 microfarad to last longer.
If the 5V line is ok the problem could be the harddisk,this is not traceable without the proper software.
Aug 13, 2009 | JVC SR-DVM700 DVD Recorder/HDD Recorder
Unit shows 'loading' continuously
This player is equipped to do a self power on test to all pain parts of the player to assertain everything is ok. The blue light will keep flasing until it completes its task and then the blue light will stop flashing and you you can start reusing it.....................sodeep
Jul 30, 2009 | JVC DR-MH30 DVD Recorder
JVC DR-MH30S DVD Recorder Image file
ciao! tutti vittime del dvd rec [jvc dr mh20-]..jvc dr mh 30...jvc dr mh 50..e un risolvere dell problema di LOADING...il mio jvc dr mh30..di 6 mese e roto ..ma trovo risolvere..difetto e nel hdd,160gb..e in corrozione..e roto hardisk,solo sistema operativo.......con softer COPY CLONE PRO..free da iternet.scarica nell cd room..nel avvio dell pc,che sono due hdd,uno rotto ,e uno buono..guarda instruzione dell cd..e tutto ok,per copy di hdd..e tutto ok per legare poi nell dvd rec jvc dr mh 30..ho provato io e tutto ok...ma io ho trovato hdd dell dvd rec jvc dr mh20..e io ho un dvd rec jvc dr30..ce un problema picollo dopo copy cloner,,mio dvd rec mi conosci solo 80gb..ma perche e in origine da dvd rec jvc dr mh20[80gb]..cercho un hdd di dvd rec drm h30..opure jvc dr mh50..per copy cloner,mio hdd,per conosciere 160gb..opure 250gb..atentti problema di LOADING..e nell due alimenti di hdd..e suporte di dvd..sono quattro line..12v..terra..terra..5v....sono simille anche perhdd..anche per suporte dvd..controla nel condizione di LOADING..se non sono precise..voltaggio..persempio..12v=10v..opure 5v....4.2v..e perdita..da un contesatore electrolitica.e asciugato da lavoro fastidiosa.......se aiuto da poco..non lo so aspettiamo nell mio e-mail....arivederci[ agimqosesda@yahoo.com ]
Apr 14, 2008 | JVC DR-MH30S DVD Recorder
JVC DR-M10 DVD Recorder not working
Contact JVC @ 800-252-5722, the "loading" is a known bug and they will fix this defect at n/c even if it's out of warranty period.
Mar 12, 2008 | Televison & Video
PROBLEM WITH MY DVD-HDD VIDEO RECORDER
Yes there is a high probability that the 5v power supply has suffered damage. Anyways just check if the drive is ejecting properly without placing any DVD. If it doesn't then its confirmed that the ps is the culprit. try it and let me know..
Feb 23, 2008 | JVC DR-MH30S DVD Recorder
Not responding after flashing "loading" for 1 minute then get message R-Lk --:-- on display
Hard drive issue or power supply. Power supply prone to bad capacitors (look for leakage/swollen tops)
If hard drive faulty you'll need a new one which is no small task. Disk contains firmware and custom file system and smallest I've got image is 10.7gig
Feb 02, 2008 | JVC DR-MH30S DVD Recorder
JVC DR-MH30S LOADING
Had this JVC recorder for a couple of years, It has always take ages to
boot up and start working now its stuck on "Loading" on the display.
Anyone no of a reset seqence that will restart the machine
Nov 20, 2007 | JVC DR-MH30S DVD Recorder
JVC DR-MH30S DVD Recorder Logo
310 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
