Question about Aloha Housewares Breeze 29" Tower Fan
Rotate It will turn a little but then starts to click i took the front cover off but really couldnt see anything is there a track or something it moves maybe it jumped off track thanks...
  • Anonymous Sep 26, 2008
    My fan does the same thing. Rotates around and makes a loud clicking sound.
Throw it in the junk.
Posted on Feb 16, 2008
Intermittent grinding noise while driving
replace the front disc pads /rotor
check wheel bearings for adjustment and serviceability
Apr 25, 2017 | 1999 Ford Escort
Changing dryer belt on kirkland/whirlpool dryer took apart dryer but dont see where belt suppose to mount.
Hello. The belt goes around the tub and the tension pulley. In fact, it is always a good idea to replace both the belt and the idler/tension pulley at the same time. J.
If you want a schematic go to and enter your model number. J.
Jun 27, 2010 | Whirlpool LER4634J Electric Dryer
Passenger seat doing the same thing
I have a 95 960 wagon and my seats have circuit boards
Sep 24, 2009 | 1996 Volvo 960
2002 Saturn Vue: Replacing rear brake shoes
If you are using a screwdriver instead of a brake spoon - then you will need two screwdrivers - one to rotate the adjuster star and one to push the plate back that holds it.
Jun 20, 2009 | 2002 Saturn VUE
I have a 2002 daewoo nubira cdx
Well without seeing it I don't know whats bent or not but your caster angle causes a pull since it is pulling right you need to add more caster to the right side or make the left side caster less.If it is the tires rotate left front to the right front and the right front to the left if it goes straight or pulls left its in the tires if it still goes right its in the alignment.
Jun 15, 2009 | 2002 Daewoo Nubira
Kyocera finecam 410 "cover open"
i had a camera that did the same thing. on mine there was a little tab on the memory card cover door thing that pushed a little button. i think a piece of the little tab on mine broke off so it wasnt pushing the button so i took a little piece of paper or something and folded it really small and set it on top of the little button thing and then closed the door and that worked for me
Feb 19, 2009 | Kyocera Finecam M400R Digital Camera
Can't put ANY disc in! White plastic piece blocking my way.
you will have to crack it open again like you did before, when you have the metal case and the top guide cover off you will see 4 little rollers , two on each side, these guide the disk in. .
(with the console front facing you) in th middle you will see the offending white stopper, DONT TRY AND FORCE IT DOWN !!! this will really bugger it up.
the problem is , the system thinks there is still a disc in there , so were gunna trick it o.k ?
to do this you need the system on. for the sake of your eyes put the round white cup with the magnet in it over the lens,magnet side up.
VERY IMPORTANT !!! do not touch anything other than i say.....zap!
turn it on and touch the sensor to load it up (hold the cover over it to locate it exactly)
in front of the right front roller you will see a white stick poking up that has its own little track it can travel around. gently guide that stick back , you should notice the system starting to read and all the rollers will slide open (you may have to help them a little (touch only the rollers)
when there all back , you system thinks theres a disc in , so press the eject sensor (line it up with the cover again)
watch with joy as the white stopper drops down.
good luck
Feb 02, 2009 | Sony Playstation 3 (PS3) Console
Minolta Magicolor Fatal Error
Remove each of your cartridges one at a time and see if you can spin the toner rollers by pushing on the little white plastic gears with your finger. They will be tight but you should be able to spin the roller by moving the little gears around.
My printer started giving the Fatal Error Code 17H and I did all the removal of the four color cartridges and re-seating each of them to no avail. After removing each cartridge and checking to see if I could rotate the toner roller I found that the yellow cartridge was extremely tight. I took the cartridge outside and used a can of compressed air to blow all the toner off the roller and tapped the cartridge on all corners and shook it back and forth several time. Finally I was able to get the toner roller so that it would rotate when pushing the little white gears like the other three cartridges.
After replacing the cartridge in the printer it worked with no more error codes. Hopefully this will fix the problem until I can order a new yellow cartridge.
Jan 07, 2008 | Konica Minolta magicolor 2300DL Laser...
My sansa won't turn on!!
I can help you with the "bad track." That error message will come up once in a while. The files in your computr are not corrupted or anything: only the sansa's files are. Taking those bad tracks off won't help, you have to format it or something (I'm sorry, I forget excatly what it is!) but if you right-click on the sansa in My Computer theres OPEN, EXPLORE, and then FORMAT. This will wipe everything off of the mp3 player, but the problem you have with the bad tracks should be fixed. Just upload them again. I am really sorry I can't tell you how to fix your other problem, I'm having a similar problem with mine right now (I formatted it, then it stopped responding to my computer and won't show any image on the screen, just white letters).
Jul 12, 2007 | SanDisk Sansa e250 MP3 Player
How to rotate a video clip I took vertically??
Start - Programs - Windows Movie Maker
Click Import Media - select the video clip you want to rotate from your files and point and click on it to highlight it - then click the import button lower right corner of screen.
When the file name appears - drag the clip to the video line at the bottom of the screen - point at file name and hold down right mouse button while you move the mouse to point at the video timeline then let go of the right button to drop the video into the timeline.
Point and RIGHT click on the clip you just added to the timeline
Click Effects
Scroll down to Rotate 90 and click to highlight it (you could also flip the video with 180 or 270)
Click the ADD button
Then click OK
The video will rotate.
Be sure to publish and save the new video with a name you can find...
File - Publish Movie - to computer will save it as a file on your PC - to DVD will start another program to create a DVD...
Have Fun
Jun 03, 2006 | Canon PowerShot S410 / IXUS 430 Digital...
Aloha Housewares Breeze 29" Tower Fan Logo
87 people viewed this question
Top Aloha Housewares Dryers Experts
Cesar Quant
Cesar Quant
Craig Butler
Craig Butler
Are you an Aloha Housewares Dryer Expert? Answer questions, earn points and help others
