Home | Air Conditioners | The last couple of day...
Air Conditioners
Problem for Air Conditioners
Generic problem for all Air Conditioners
The last couple of days our heat pump wil...
By wbwutke on Jul 04, 2009
the last couple of days our heat pump will not cool below 80 degrees even if we set the temp to 65. The unit keeps running.
last week the heat pump worked very well. The unit is 10 years old.
Best Solution
posted on Jul 05, 2009
Very Helpful)
james3751
Rank: Guru
Rating: 91%, 171 votes
Check the outside unit. Feel the larger line to see if it is cold. Is the condensor dirty. If you have a way to measure temp. Take the return air at the filer and the closest grille temp and subtract. It should be between 19 to 23 degress. If not you have a problem. Could be refrigerant or some other problem. Either way you need to get it checked out by a service tech. Ask for free estimate that way you are going to know how much it cost before hand. Rus
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Air Conditioners
Questions and Unsolved Problems for Air Conditioners
Answer
frigidare gallery 30-inch freestanding electric range model:lgef3033kb
Answer
I found a new ap500pf samsung 49600 btu split air floor standing unit for sale by private seller. I... (More)
Answer
i have a brivis contour cooler although i gob to switch it on but has no power, what do i do?
Answer
DeLonghi Pinguino 10.000 BTU Portable Air Conditioner (NF100) manual
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Air Conditioners:
Top Air Conditioner Experts
Rank: Guru Guru
Solutions: 1493
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Air Conditioner Experts
Top Air Conditioner Repair
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
