I need a diagram to find the problem with a range top unit that won't turn off.
Hey friend, thanks for your inquiry!
I have located the wiring diagram for your Electrolux range, EW30EF65GSH. The link will be attached. I hope this information provides you efficient assistance. -Matt
Frigidaire Manual Search Results
SOURCE: wiring diagram
try the whirlpool or kitchen-aid web sites I looked up your model # at 1st source parts and that model is not there
SOURCE: How fix blown element on Electrolux induction range?
If it's a year old and under a 5 year warranty then it will be covered under the warranty and shouldn't cost you a dime. If it happens again then speak to someone about getting a different range since you may have received a lemon.
Thank you for your post, friend!
From my understanding you are searching for a diagram of your Electrolux range. I have located the manuals and diagrams for your appliance. I hope this helps. -Matt
Hi Amy Goduti - If the oven is working but the cook top is not, the range may possibly be experiencing an issue with a wiring failure or EOC. Try resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and turn on the cook top. If it proves to be ineffective, contact a professional to move forward accurately.
Hello Elizabeth P Cochran - Try resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart unit. If the door does not open, then it sounds like the washer is possibly experiencing a communication problem with the control board, wiring failure or faulty door lock. Contact a professional to move forward accurately to properly diagnose/repair unit.
Hello - If the oven is working but the cook top is not, the range may possibly be experiencing an issue with a wiring failure or EOC. Try resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and turn on the cook top. If it proves to be ineffective, contact a professional to move forward accurately.
