Question about Microwave Ovens
Microwave oven We have an over the range microwave oven. It is a Whirlpool Model no. MH6150XMT-0 When we put time on the timer it takes about 6 seconds to run down a minute. Plus it is not Heating. Could this be the electronic panel.
  • deaconshel Nov 18, 2007
    Thanks for your Help. The hard reset worked and I am very thankful.
  • Microwave Ovens Master
  • 9,098 Answers
Yes, it could be. The first thing to try is a "hard reset".
Unplug it from the power line for a few minutes, plug it back in, then try again.
Let us know if the hard reset doen't fix it.
We appreciate your thoughtful rating of our answer.
Posted on Nov 17, 2007
How do i fix a whirlpool microwave and range hood combo
869a8192-23d2-4ffd-9f6d-9d352dca9204.pngWhat is the model number? F-6 is a Microwave Relay Failure.
1. Check wiring to Relay 4903 for short circuits.
2. If wiring is OK:
• Unplug microwave oven or disconnect power.
• Replace electronic control.
• Plug in microwave oven or reconnect power.
Sea Breeze
Jul 25, 2013 | Microwave Ovens
Whirlpool MH2155XPQ microwave range hood lights, timers, touchpad chimes, etc. work, it just will not cook food.. Can you help me.
probably the diodes have blown, easy fix if you can solder and use a multi meter.Get back to me if you want to try it
Jul 14, 2010 | Whirlpool MH2155XP Microwave Oven
Can't take down/unsinstall over range whirlpool microwave
You can download the installation instructions for this model here.
Essentially you'll take it in reverse order.
William E. Miller, AS-EET
Microwave Oven Control Panel Repair Nationwide
May 28, 2010 | Whirlpool MH7140XF Microwave Oven
Remove a whirlpool over the range microwave oven
Jim here. In cabinet above microwave, locate 2 mounting bolts.
Place a box on the stove top to support the microwave once the mounting bolts are removed (you may wish to cover the box with a thick towel or small throw rug).
1. Unplug microwave.
2. Remove both mounting bolts from top of microwave (they secure it to the overhead cabinet).
3. With microwave front angled down onto box, pull some of power cord out of hole (to provide some moving space).
4. With microwave hand supported, remove box from stove top (a second set of hands would be helpful here).
5. HARD PART- detach top of microwave back from wall mounting plate by placing a hand under the bottom rear of the microwave and pushing up. (Wall mounting plate is screwed into the wall behind the microwave and provides both top and bottom support to the back of the microwave.)
6. Lower front of microwave until you can see about a 1-inch clearance between the top-rear of the microwave and the cabinet above it.
7. Firmly lift the microwave straight up and then bring forward. It should be free of the wall mounting plate.
Sep 30, 2009 | Maytag MMV4205 Microwave Oven
Whirlpool Microwave Oven Serial Number MH660XW-0
Hi Adam,
Built in over the range? The models change so rapidly unless it is less than a year old there probably wont be an identical replacement, Fortunately the mounting brackets remain close if you stay in the same brand. Whirlpools can be purchased at almost any retailer like Lowe's, Sears, BestBuy etc. Measure the the original and look for one that fits that dimension.
Jun 09, 2009 | Whirlpool Microwave Ovens
Buttons including light, cook time, etc will work infrequently
Good news, even though the electronic controls (circuit boards) are different, the touch pads for the two units are the same. As far as the nomenclature behind the model numbers/letters, this information is rarely known or needed.
Please take the time to give this solution a fix ya rating.
Below are some applicable links for you for future reference.
owners manual/parts list for MH6150XMT
owners manual/parts list for MH6140XK
Feb 09, 2009 | Whirlpool MH7140XF Microwave Oven
Microwave Ovens Logo
228 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
