I have replaced the coil with matching ignitor, spark plug, cleaned all the contactswith no luck. What should I try next?
SOURCE: Toro walk behind model 20025 Gas running through the carburetor
Carb. float must be stuck open. First if you have no fuel in the tank it must all be in the crankcase.Drain the oil and refill and also check the carb as the float has to be sticking open. Hope this will help you. Donnyb60
SOURCE: can't start toro mower. cleaned spark plug , new
Hello:
There are 2 Possible Causes for this Problem.
1- The Carburetor Requires Soaking and Cleaning.
2- The Valve Clearances Require Setting.
You can View a Breakdown of this Unit at the Following Site Addy.
https://lookup3.toro.com/partdex/default.cfm
Hope this Helps.
Good Luck
Respectfully
John
SOURCE: My toro self propelled only runs for a few
Have you tried replacing the gas cap? I had the same problem with my mower and did everything you have done, changed gas cap no problem since
SOURCE: 6.5 toro walk behind self propell b&s engine.
Try adjusting your self propel cable. A slight extension of the cable (1/4 inch) will double speed, so do a little at a time. Take the back guard off and clean debris 2 or 3 screws and it is just a cover so nothing will pop out unless that is your real problem. You should have grease fittings behind rear wheels so squirt 2 times with grease gun in each wheel and 1 squirt every 3rd mow.
SOURCE: I have a 5 year old Toro mower. No spark at the plug. Now what?
Hi there
If you don't have spark that means you have a bad ignition coil . To locate the ignition coil just follow the spark plug wire . First try to readjust the coil because with the time most of the coils goes loose with the vibration . The coil should have 2 bolts holding it against the flywheel . To readjust get a piece of paper and put it betwen the coil and flywhell and retight the bolts , remove the paper and see if there's spark , if not you have to replace the coil.
Hope this help
