SOURCE: saw runs for 3-4 minutes then dies
check the spark plug
change the seals with new ones
check compression
regards Mihai71
SOURCE: Brand new Husqvarna 340e chain saw dies after 10 to 20 minutes.
Hi
Find out where is its airating sistem.It equalises the presure between the interior and exterior of the gas tank.Disassembly and clean it.
regards savumihai71
SOURCE: mccullough chain saw pm610 chain slips -- maybe clutch issue
I just had this problem. It is possible that your chain drive teeth have jumped off the drive sprocket. There is a guide for the chain to follow and is decievingly difficult to verify that the teeth are in the drive sprocket. Turn the saw upside down, and look at the clutch. Check the chain to see if the chain is actually on the sprocket and not beside it. It looks right, but it's not.
SOURCE: Husqvarna chain saw starts and runs for a few
sound like the ignition coil is bad.......they have had some issues with them.are you taking the saw to a husquvarna dealer or just taking it back to lowes.some times they don't send them to a husquvarna dealer....
SOURCE: Husqvarna chain saw starts and runs for 20 minutes then stops.
two things could be happening.......first is vapor lock......make sure you breather tube is clear and working........next is ....it could have a bad ignition coil on it.....after the coil gets hot the spark can become irratic or just not work any more.....
