solid green led followed by flashing green led which flashes five times before resetting, followed...
(More)
solid green led followed by flashing green led which flashes five times before resetting, followed by a solid red led
I am installing a used heat pump into my exsisting gas furnace. All have left to do before charging...
(More)
I am installing a used heat pump into my exsisting gas furnace. All have left to do before charging is wire up the low voltage for the heat pump. I can't seem to find out where the wires go from the heat pump. It has 4 wires: Brown
Hello.. slight problem. Rudd silouette II a/c gas furnace. Fan runs on low speed, and will not shut...
(More)
Hello.. slight problem. Rudd silouette II a/c gas furnace. Fan runs on low speed, and will not shut off. a/c comes on, and get cold, but blows on low. seem like the switch is switched to on, instead of auto.. CVould this be control board? Thanks
