2002 Monaco coach/2 13,500 rooftop units that shop said were working fine. Units were starting, run a minute or so then stop. Replaced control center with new one, reset it, seemed to work better for a couple of weeks then same problem. Trying to reset today and can only get EE on display when resetting - won't go to modes or zone control. Both control centers, old & new, give the same error message. Help!
You need to check the cable that connects the Comfort Control to the upper unit. This cable has four wires and should have continuity through all wires. If there is a break in one of the wires or a short, it will cause the CCC to fail and report an error. If all this is fine, then you have a bad control unit in the main unit. Try unplugging the rear unit from the control board and then resetting the Tstat, if this works, then there is a communication problem between the front AC control board and the rear AC control board or the rear control board is bad. Check the cable between the front and rear AC for OK. If it is alright, then you have a bad control unit in the front unit.
Another quick check is to remove the inner shroud from the front unit pull down the control box. Remove the access cover and view the dip switch panel located inside. It should be labeled Zone 1 Zone 2 etc...try turning off Zone 2 and furnace and resetting the tstat. If this works then turn zone 2 on and reset the tstat. If this is ok, then turn the furnace on and reset again. If this works, then all should be ok. If one of these fails, then you can pinpoint the problem there and move forward.
Our Dometic Duo-Therm air conditioner/furnace will not shut off. The only way is to pull the 20 amp...
(More)
Our Dometic Duo-Therm air conditioner/furnace will not shut off. The only way is to pull the 20 amp furnace fuse but the power red/green lights are still on. It is getting hot in here
I have a tempstar with 6 wires. Green, Blue, Red, Yellow,White, and Orange. I am trying to install a...
(More)
I have a tempstar with 6 wires. Green, Blue, Red, Yellow,White, and Orange. I am trying to install a White Rodgers 300 thermostat and letters are not matching up. The thermostat has G, A, RC, RH, O, B, Y, and W. I don't know where to hook the blue wire which was labeled C. Unless it goes to RC and the red goes to RH could you please help? Thanks
