Why does the Gas gauge reads full all the time even when the car is shut off for hours?
SOURCE: filling gas tank
There is a vent pipe that runs along the fill pipe, they get kinked and cause this concern (tank can't vent air when filling), the only fix is to replace the fill pipe assembly.
SOURCE: fuel gauge not working on 2005 ford mustang
Sending unit is in gas tank. usually as an assembly with the electric pump. These aren't cheap either, If you know a mechanic you can trust ask him how much to install a new one, I can get them wholesale for less than two hundred dollars, but of course retail probably more like 250.00 Hope this helps you!
SOURCE: Gas Gauge not reading correctly
The most likely culprit is the sending unit in the tank. They are relatively easy to change, as long as you don't have much fuel in the tank. It's a mechanical unit that has a float that raises and lowers with the fuel level, however with age, the floats can develop leaks and no longer float, of the electronic portion of the unit can go bad and not register the proper level. They are replaced and an entire unit, so it doesn't matter which happened, you will need to change the fuel tank sending unit.
SOURCE: After filling my fuel tank, gauge does not go to
There is a TSB on high sulfur fuel usage, and how it impacts the fuel level resistance.
If you change fuel, it might start working again. The TSB is : ERRATIC FUEL GAUGE OPERATION TSB 08-2-9
Publication Date: January 22, 2008
FORD: 2004-2008 F-150
LINCOLN: 2006-2008 Mark LT
ISSUE:
Some 2004-2008 F-150 and 2006-2008 Mark LT vehicles, built before 12/3/2007, may exhibit erratic fuel gauge operation or illuminated malfunction indicator lamp (MIL) with diagnostic trouble codes (DTCs) P0460 or P0463, and/or Instrument Cluster Module DTC B1201. This may be caused by sulfur contamination in the fuel causing an open or high resistance in the fuel level sender.
ACTION:
Follow the Service Procedure steps to correct the condition.
SERVICE PROCEDURE
Install a new fuel level sender following the service procedure instruction sheet provided in the fuel sender kit.
PART NUMBER PART NAME
8L3Z-9A213-E Kit - Fuel Sender (2006 starting 12/8/2005 through 2008 - FFV-26 Gal Tank - 126/132" WB )
8L3Z-9A213-F Kit - Fuel Sender (2006 starting 12/8/2005 through 2008 - FFV-30 Gal Tank - 139" WB)
8L3Z-9A213-G Kit - Fuel Sender (2006 starting 12/8/2005 through 2008 - FFV-27 Gal Tank - 145/151/163" WB
8L3Z-9A213-H Kit - Fuel Sender (2006 starting 12/8/2005 through 2008 - FFV-36 Gal Tank - 145/151/163" WB
8L3Z-9A213-A Kit - Fuel Sender (2004 through 2008 - Gas-26 Gal Tank - 126/132" WB
8L3Z-9A213-B Kit - Fuel Sender (2004 through 2008 - Gas-30 Gal Tank - 139" WB
8L3Z-9A213-C Kit - Fuel Sender (2004 through 2008 - Gas-27 Gal Tank - 145/151/163" WB
8L3Z-9A213-D Kit - Fuel Sender (2004 through 2008 - Gas-36 Gal Tank - 145/151/163"WB
WARRANTY STATUS:
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage And Emissions Warranty Coverage
IMPORTANT: Warranty coverage limits/policies are not altered by a TSB. Warranty coverage limits are determined by the identified causal part.
OPERATION DESCRIPTION TIME
080209A 2004-2008 F-150, 2006-2008 Mark LT: Install New Fuel Level Sender, Includes Time To Remove And Install Fuel Tank (Do Not Use With 9002A, 9002A4, 9002A6) 1.9 Hrs.
DEALER CODING
BASIC PART NO. CONDITION CODE
9A299 42
SOURCE: 2006 ford f350 diesel fuel gauge read empty then
2006 F350 6.0 Engine light Code is reading bad fuel gauge sensor could this effect fuel pump and performance. Can I wait until have time to change.
