RCA HD52W140 52 in. Rear Projection Television
Problem for RCA HD52W140 52 in. Rear Projection Television
Tv cherps when you turn it on
By tamaralynn1 on Jul 04, 2009
my tv makes cherping sounds when i turn it on what could be wrong
Comments:
Jul 04, 2009
- there is no picture or sound
Jul 04, 2009
Jul 04, 2009
Jul 04, 2009
Best Solution
posted on Jul 20, 2009
Very Helpful)
palaboy
Rank: Wiz  RCA Televisions & Videos  Expert
Rating: 82%, 1196 votes
hi,
have a voltage check on the power supply it might not have enough, to power up the horizontal deflection circuits.
maybe the supply rail B+ is only about 45V or still lower
solution : replace the horizontal deflection flyback transformer maybe partially shorted
maybe no voltage at all
solution : check horizontal output transistor might be defective, replace if found shorted
maybe there is a good supply say at least 110V , but no oscillator drive on the horizontal output transistor, or blocked oscillator signal drive
hope this helps, thanks for using Fixya!
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for RCA HD52W140 52 in. Rear
Questions and Unsolved Problems for RCA HD52W140 52 in. Rear
Do you recommend RCA HD52W140 52 in. Rear Projection Television?
Answer
Answer
just wonder where i can buy or order this and if it's ez to do urself?
Answer
my rca tv wil turn on sometimes other times it acts like its going to turn off but it just turns its... (More)
Answer
picture is fine but there is like a white noise sound like a fuzz when there is no reception.it just... (More)
Answer
tried turning on the tv but it only clicks like its going to turn on but then it clicks again and... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For RCA HD52W140 52 in. Rear...:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
