SOURCE: GE Profile CF24W-PL
Make sure the fan inside the freezer is running. If so, remove the cover from the back of inside of the freezer. If it is clogged with frost you have a defrost circuit problem. Most likely the defrost heater mounted at the bottom of the evaporator coil is burned out.
Post back with any questions and let me know what you find.
Thanks/Mike
SOURCE: right side of refrigerator not cooling; frezzer working great
Ice build up on back wall could be defrost thermostat or faulty defrost heater
SOURCE: freezer works fine but the refrigerator is not
Need you to unplug and lets have a look inside the rear panel in freezer at the evaporator. That is the sign that defrost has stopped. If covered with ice defrost with a hair dryer. Look near bottom there is a defrost heater. Look to see if burned out if glass tube with heater coil inside. Then let me now. If so you will need to change the defrost heater a defrost thermostat. Let me know what you find, Sea Breeze.
SOURCE: My refrigerator is not cooling. The freezer is
With the PSS26MRSS model the mother control board is suspect in that happening. Unplug and pull away from the wall and remove the cover over a panel that has the board inside. Look at both sides of the board for burn marks. Let me know what you find and if you find the board looks OK then we need to look at the compressor relay and start relay. Thanks, Sea Breeze
SOURCE: My freezer is cooling fine but the refrigerator
check and make sure the damper vent door is opening fully between the refrige and freezer compartments so as to let cold air from freezer into the refrige
Testimonial: "That appears to have been the problem."
Its defrost problem, the freezer should cool,
then freeze, then defrost cycle should start. In your case freezer is cooling,
then freezing, but its not defrosting. That's why fridge section is not
cooling.-------
Click this link below and follow the
troubleshooting:----
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
This will help.Thanks.Helpmech/.
cooling.-------
cooling.-------
cooling.-------
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Check
out these tips...they can help you figure out what is going wrong
with your refrigerator and why it is not cooling
Refrigerator
not Cooling
or Fridge not Cooling
How to Defrost Refrigerator Defrost
Timer Problem
Water
Running in refrigerator
from Freezer
Refrigerator
heatman101
