Honeywell Electronic Programmable Heat/Cool Thermostat - CT3300A100 Heater
Problem for Honeywell Electronic Programmable Heat/Cool Thermostat -...
Furnace won't shut off
By daisy123456 on Jul 04, 2009
I have a York M8 series furnace that will not shut off.
Solution #1
posted on Sep 12, 2009
Not Rated)
mac5932002
Rank: Guru  Honeywell Air Conditioners  Expert
Rating: 88%, 64 votes
your control may be shorted due to getting wet. make sure the coil isnt frozen or that the drain line is clear and the inside of the furnace isnt wet. sometimes just letting it dry could solve the problem depending on the severity of water damage of course. more info would be needed to give you further diagnosis
Was this helpful?
Yes
No
Popular Solutions for Honeywell Electronic
Questions and Unsolved Problems for Honeywell Electronic
Do you recommend Honeywell Electronic Programmable Heat/Cool Thermostat - CT3300A100 Heater?
Answer
Answer
We recently bought a house that has a ritetemp programmable thermostat in it. I can't find a model#... (More)
Answer
hcw8o will not work , i think it is something to do with a flashing red light that changes when the... (More)
Answer
i neeed to program my thermostat to when i want to turn it on it wil turn on some times only in... (More)
Answer
i have a CM61ng linked to an isar combi boiler,the heating is permanantly on and the settings on the... (More)
Answer
I replaced the 50A51-495 two stage automatic interrupted ignition control and must have not... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Heaters Experts
Top Heater Repair
(800) 905-9506
Traditional water heaters use a storage tank to...
Plumbing Key
(888) 448-9872
Nationwide plumbers where ever you need us any...
plumbingcoop
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
