When I open the freezer door the light blinks red. Is this a normal feature?
SOURCE: Ice maker has ice in it but will not dump in bin!
before i would worry about the lights flashing lets pull the front cover off of the icemaker and verify that the drive gear is not broken.
on the bottom of the icemaker is 1 screw. remove that screw then just slide the entire icemaker out of the refrig so that you can access the front cover. if the gear is broken just replace the front motor module pt# 8201515
if the gear is fine then located in the toe grille of your refrig is a tech sheet that will help you troubleshoot red light blinking.
SOURCE: Kenmore bottom freezer 795.75092402 freezer doesn't open
After several hours working and moving the door, I was able to slide open the door. Found out that the ice maker was leaking and the water was in the bottom an it frozen and that was stopping the door to open.
SOURCE: Kenmore Elite ice maker is not working & red light is blinking
Most likely a problem with the main ice making unit itself. I bought mine at ebay for $49 including shipping. Very simple to replace. You just swap the wiring harness and bottom plate. Takes about 20 minutes to do.
Make sure you do the IR led test. If you think you IR sender and receiver are bad to, $57 on ebay for the set. Most likely not your water solenoid in the lower back of frig (it gets the signal to turn on from the receiver module of the IR board.
Probably not your water filter (cuz the front water dispenser still probably works right?)
And probably not a clogged or frozen line.
Good luck. When it doubt, trust ebay!
SOURCE: Kenmore 106.56542400 No ice, red lite blinking
Many people claim that raising the freezer temperature and using a hair dryer to defrost the ice maker will solve the problem. As for the blinking light I believe that is part of the ice maker sensor to tell if ice storage is full or not. Here is a link to the troubleshooting forum. Thanks, Sea Breeze
http://www.thriftyfun.com/tf50663056.tip.html
SOURCE: Kenmore side by side refrigerator Ice maker not working
Found out we still had a warranty/service contract on it. Contacted SEARs and I explained problem to technician. Scheduled house call is Friday.
