Question about Soyo SY-P4VTP VIA PT800 Socket 478 ATX Motherboard (11999)
Wd sata hard drive is not being detected by the mobo
I recently bought a new 400gig hd from western digital. When I hooked up the hd to the Soyo SY-P4VTP MD I have had no luck with it showing up as being detected. With that being said I cannot progress with installing the new windows vista. I have checked all the connections and everything seems to be running well powerwise (when turned on I can hear the drive running).
Please help
  • 143 Answers
Sounds like issues I've had in the past...
But the funny thing was that after all was said and done, the fix that I figured out what easy.
Let's see if this works for you.
Get into your motherboard's BIOS setup on bootup. Check into the first section of the BIOS labeled "Standard CMOS Settings". You should find settings for all drivers there.
You have a set of various settings such as "User" or "Auto" for each drive entry there. Set them all to Auto so that they can properly detect the drive's settings on startup.
If you use "User" it will be looking for user-defined settings for each drive channel. These don't typically work too well.
The only thing that eludes me here is this... What kind of drive is it? I'm assuming that it's an IDE drive. But it could also be a SATA drive.. Given it's size, tha'ts probably the case.
I'm not sure exactly how your BIOS is set up of course... But be dynamic and apply the principles I have described above to whatever settings you find in your board's BIOS.
You might also want to check to make sure that the jumper on the back end of the drive is set correctly, too. If it's a newer SATA drive that is capable of running at 300, then make sure to try setting it to the previous 150 speed and see if that works. It may mean that the drive's speed is set too high for the motherboard's SATA ports.
I'm more familiar with Seagate drives, though. Yours is a Western Digital. They're usually a bit different of course.
Keep us updated. :)
Posted on Nov 10, 2007
Hi, I want to know how to install the WD10EARS-00Y5B1 drivers? Okay, the problem is, that my computer doesn't recognise my SATA Hard Disk. I have Windows 7 Home Premium, and another SATA Hard Drive. I...
there are no drivers required for a hard drive.
Windows 7 should automatically detect the new hard drive and it should show up in disk management to format or prompt you to format.
Check your cable connections again.
Otherwise your new hard drive may be DOA. Return it to the store that you purchased from.
Mar 26, 2011 | Western Digital WD Caviar Green WD10EARS -...
Hello my dell laptop's WD 500 BEVT stopped booting. a technician took it out and since then i bought usb connector trying to connect my newly housed wd with my other computers. although it will be...
you need to connect this using a sata cable and sata power lead to a spare sata port on your computer, t should then be recognised as a legitimate drive
Mar 25, 2011 | Western Digital Passport WDXML800UE...
Unable to format a Western Digital Caviar Green 2TB SATA 3.5" Desktop Hard Drive
In your formatting on a windows machine you can format by right clicking the new drive and select format. Or you can format by opening manager by right clicking on my computer and choose manage then go to disk management and locat the new drive and right click format
Mar 11, 2011 | Western Digital Caviar Green 2TB SATA 3.5"...
My wd hard drive is not detecting. i want to data backup.
Only solution for that is to try to make that WD HD to be ur SLAVE! So that u could get the DATA u wanted!
Nov 29, 2010 | Western Digital Caviar SE WD800JD SATA...
My western digital Passport 320Gb usb drive is not detected
hi ,
looks like u primary hard drive is inside the laptop and so should be displayed as c : drive ,
and the reason , the external hard drive is not displayed seperately is csue ., the external HD  may be added as slave to the internal HD .,
can u tell me ,make a right click on c:/ drive and choose properties : and tell the totalsize dispalyed
Jul 23, 2009 | Western Digital Passport WDXML800UE...
WD Caviar SE16 WD3200AAKS 320GB 7200 not recognized at install
Windows XP does not have built in SATA drivers. You will need to download the XP drivers from Western Digital's website and install before the computer will allow you to format and use your new drive. Hope this helps.
Jul 18, 2009 | Western Digital (WD3200JS) 320 GB Hard...
SOYO KT600 Dragon Plus mobo not recognize WD Caviar SATA 1TB HDD
Yuck! Soyo filed for bankruptcy in May and their website is gone!
You need to enable the SATA in the rom bios AND install the drivers for it; but, I hope you have the manual and the CD.
Jul 05, 2009 | Soyo Computers & Internet
Installing windows xp with 2 new sata wd 150g 10k 16m raptors to NO avail...
I guess you are trying to install Windows XP in RAID 0 configuration. If so, you need to do several steps:
1. Configure the bios to work as RAID 0
2. Download the RAID driver from the mobo vendor site, copy it onto a floppy disk and have it ready for when Windows asks for it.
See this link for detailed example
In SATA there is no master/slave configuration, so there is no need for jumpers.
I hope this answers your question.
Dec 26, 2007 | Western Digital (WD1500ADFD) 150 GB Hard...
Wd800jd sata hard drive not recognized in bios on boot up
Hi, A couple of ideas: 1. There are 3 versions of this motherboard: Dragon Plus, V1.0 & V2.0, perhaps your BIOS needs an update to be able to recognize the new HD. This of course would require flashing; 2. There are two variations of a WD SATA hard drive: Serial ATA amd Serial ATA II; 3. Re Jumper settings: the eight-pin jumper block is only used to enable power management on the drive. There are no master/slave settings since there is only one drive per cable; 4. If you are fresh installing Windows on it, you need to press F6 when asked by the Windows Installer and follow on-screen instructions. Hope this be of some help/idea. Post back how things turn up or should you need further information.
Sep 17, 2007 | Western Digital Caviar SE WD800JD SATA...
Computers & Internet Logo
155 people viewed this question
Top Soyo Computers & Internet Experts
Roy May
Matson Kurian
Matson Kurian
Are you a Soyo Computer and Internet Expert? Answer questions, earn points and help others
