Hello sir, that is a on going problem with power washers the pump not working, than works sporadically. the main cause is leaving the pressure hose hooked up to the machine over a long period of ,not draining hose & machine, in the winter time the hose & pump willfreeze causing hose & pump to expand and burst. build up of calcium deposits from hard water clogging up pump nozzle,valves in the gun handle,clogging hose fittings and screens.one of these has to be your problem.you can find a parts brake down at KARCHER.COM.orRJ BOWERS.COM . and manuals,these are good info,sites,hope this helps, MrFixIt,oh could you please rate this solutions.thank you.,.,.
My pull cord to my pressure washer is hard to pull and it's not starting. Why? This all started...
(More)
My pull cord to my pressure washer is hard to pull and it's not starting. Why? This all started after I tried to start it without the water on while attempting to start.
The on-off switch shaft broke on my K 2.89 M pressure washer and I can't get the broken piece out....
(More)
The on-off switch shaft broke on my K 2.89 M pressure washer and I can't get the broken piece out. Can you help?
we have the black tip on and have placed clear plastic hose to black plactic and the brass valve at...
(More)
we have the black tip on and have placed clear plastic hose to black plactic and the brass valve at the bottom of the washer and no siphoning
