Question about Nintendo DS Console
Power on does not power on . have it plugged in to a/c and orange light on but the system will not come on
  • bycker Nov 15, 2007
    Yeah, mine too! I can plug in the A/C chord, the orange light goes on for a split second and then goes out. Nothing else happens. ZERO POWER! -- Nintendo says that I can send it in with $75, but there's no promise to repair it! What a pain
  • 3 Answers
I had the same problem, but i fixed it myself. It sounds like the fuse ( F2) is blown on the circuit board. Have you had the ds open at anytime ? if so ,did you put the black sponge/foam back in place between the touch screen and the circuit board? if not , this will blow the fuse. if you look at the circuit board just past midway top right there is two small silver dots. ( F2 ). this should have a very thin piece of fuse wire linking them both, if not then the fuse has blown. Solder a piece of solder and "arch it" and drag from one dot to the other so it forms a link. Try it , it worked a treat on mine . Let me know if it works
Posted on Feb 20, 2008
My ups is nu meric digital problem is whenever i on my ups a orange light is burning continuously and ups is not working what is problem in that i cant understand pls tell me solution
Hi Lokesh,
Orange lights on most UPS systems we've come across indicate that the unit is overloaded - you have too many things drawing too much power plugged into it.
Hope that helps.
If you need UPS, Surge, or Power Related help contact:
Daniel with Power & Systems Innovations 800.260.2259 or go to our website:
•• If this helped - click YES :) ••
May 26, 2014 | Computers & Internet
I have a toshiba satillite pro l300. when i plug into mains only the orange light comes on and nothing else.
Try removing the battery and using the power cord to turn on the system. Usually an orange light means a battery problem.
Apr 11, 2011 | Toshiba Satellite Pro L300 Notebook
Battery? console has no charge when plugged into wall outlet I push power button blue LED comes on briefly , then red flashes 3 times, and the yellow LED lights up along with the health warning on the...
What color is the power light when the system shuts off?
    Red: If the power light is red, or flashing red, when the system turns off, then the system's battery needs to be charged.
    Blue: If the power light is blue when the system turns off, then there appears to be a problem with the system and it will need to be repaired.
    If the orange recharge indicator light blinks while the system is plugged in and charging, then it is likely that the battery is not installed properly.
    If you have ensured that the battery is installed properly but the orange light still blinks, check to make sure that the battery is a licensed by Nintendo. The only licensed Nintendo DSi battery will have the model number "TWL-003" (Nintendo DSi) or "UTL-003" (Nintendo DSi XL) and will display Nintendo's logo.
    Call 1-800-255-3700 if you still need help.
Jan 27, 2011 | Nintendo DSi Matte Blue Console
Changed the DC adapter plug it in orange light Problem with the Acer Aspire 5500 5532 5535 Laptop Computer (AS55702609RTL) PC Notebook changed the DC adapter plug it in orange light comes on charging I try...
If after the replacing the AC adapter the problem still persists , the power board on the motherboard has gone bad. The same can be repaired, but would require you to take the system in for repairs. if the system is under warranty then the best thing to do is get the motherboard replaced.
Nov 13, 2010 | Acer Aspire 5500 5570-2609 Laptop
Dell Inspiron 1525 laptop, no power light, battery light flash orange, wifi light flash blue and orange I bought the Dell Inspiron 1525 laptop in 2008. I use the laptop as a desktop, so I never plugged...
Since it sounds like an issue with the Power first try to release flea power.Disconnect the charger,remove battery,press and hold down the power button for 30 seconds.Reconnect the battery and charger.Turn on system and check if it turns on. For further help please check Dell Inspiron 1525 Manual. Also confirm if the light on the charger stays on,when connected to the system.
Mar 06, 2017 | Dell Inspiron 1525 Notebook
Mac Ibook Power supply problem
On Mac iBooks the orange light comes on when it charges the battery. Once the battery is charged it turns green. Im guessing the other powersupply was aftermarket or broken. EIther way, if it starts out green - recognizes the battery isnt full - turns orange for a while - then turns green when the battery is full, then the computer and powersupply are working perfectly. Enjoy your iBook!
Feb 27, 2009 | Apple Computers & Internet
No Power, Cannot open
contact ur dealer..its hardware problem!
Dec 27, 2008 | Compaq Presario 700 470024-192 Notebook
Solid orange light on motherboard when power light is plugged in
the light on the motherboard indicates power to the board, so it's completely normal. that might be the same for the power button light.
Nov 15, 2008 | Computers & Internet
Canon Pixma ip1500 - Orange Flashing light
may be "waste pad full" error
4 step to Reset waste ink tank counter CANON PIXMA iP 1500
STEP 1:- Disconnect printer from AC power
STEP 2:- Press and HOLD the POWER button, and connect printer to AC power
STEP 3:- release the the POWER button
STEP 4:- Press the POWER button again
Feb 05, 2008 | Computers & Internet
Gx260 pc wont start
Have you checked the post lights located in the back of the system by where the keyboard plugs in? There are is a row of 4 lights; either yellow or green. If the systems gets stuck at a particular post location, the lights will tell where. Good luck
Aug 16, 2007 | Dell OptiPlex GX260 PC Desktop
Nintendo DS Console Logo
118 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
