Home | Heaters | 1 tank feeding 3 heaters
Heaters
Problem for Heaters
Generic problem for all Heaters
By hawleycourtn on Jul 04, 2009
1 tank feeding 3 heaters (different houses)ran out out fuel for several months. Just had tank filled, only can get 1 heater to work, other 2 no ignition,therefor no fan.I have pressed the fuel set lever as directed, over 2 days have tried many times, Tank you.
Sponsored Links
Solution #1
posted on Jul 15, 2009
Not Rated)
mrrevol
Rank: Wiz
Rating: 81%, 133 votes
your filters are clogged replace and bleed system then they will light. you may also need to replace the nozzles and screens too.
Was this helpful?
Yes
No
Popular Solutions for Heaters
Questions and Unsolved Problems for Heaters
Answer
how can you buy things for less than what they ask for?
Answer
What is the safest & most cost effective patio heater
Answer
i have a pro comp pc9001 distributor multi-spark box with a pc91 coil..my problem is where does the... (More)
Answer
model # 5101 Lakewood 234R Need full wiring diagram
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Heaters:
Top Heater Experts
Rank: Guru Guru
Solutions: 1303
Experience: 15 years field experience and 5 years navy training
Ask Me
Find more Heater Experts
Top Heater Repair
(800) 905-9506
Traditional water heaters use a storage tank to...
Plumbing Key
(888) 448-9872
Nationwide plumbers where ever you need us any...
plumbingcoop
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
