SOURCE: Marine Faria depth finder, with thru the hull transducer.
I'm having the exact same problem. I spoke with the service manager at Faria (Ted) and he was thinking that as long as the gauge is showing a reading, it should default to reading the depth. I'll probably send the guage in to FARIA - they'll repair it for $55. You bring up a good point - maybe the transducer is bad? I put a call in to the Tedmeister to see what he thinks. I'll post if he sheds any light.
SOURCE: furuno 4100 depth sounder shows depth twice what it really is
check your gain setting try auto gain and try manually gaining back to see if it resolves, if yes, send unit in to furuno, if no, ducer is probably at fault.
SOURCE: My marine speed transducer needs to be replaced.
Yes. You need to make sure you get the same transducer though. With you system being that old, you may have a transducer that is old where there is not a direct replacement. You need to make sure you get the correct transducer. You may need to get a "flapper" kit to update your housing to the new style.
SOURCE: I have a GPS Map 498-depth sounder not working? Ha...
If the transducer is out of the water, you will not get a reading and see the flashing depth. You should hear and feel the clicking in the transducer when out of the water and working properly. Are you getting a temp reading when out of the water?
SOURCE: Hello, our Raymarine ST40 depth sounder on our
now there is a chance that the transducer is bad ,, but I would check the battery voltage and make sure you have a soild 12 volts to the unit. also in my many years of working with and installing these units on boats I have see the needle pins ( where the plug inserts in the back of the display unit ) bend and/or break off completely. look in the plug area of the display unit and make sure all pins are intact. one more place to look for the problem is in the plug itself, take the plug apart and inspect the wire connection and make sure they are all good. if after all the above has been checked then I would assume that it is the transducer itself.
if you have anymore questions with this problem, please feel free to write back and ask,
c...
