The main compartment of my fridge is running about 10 degrees too warm. Freezer is working fine (thank god!). Freezer is in a seperate compartment with its own door.
I did a huge defrost, hoping to melt ALL the ice in and around the fridge in case it was blocking something, but it doesn't seem to have made any difference.
Ideas? Suggestions? I am all ears. Gurus, please help!
Fridge is a Sears Coldspot. The only model number I can find is 7642010, although the Sears website tells me that isn't a model number. The other number on the plate is S53050109 if that helps at all.
Whirlpool model ET1CHEXVB or model W2RXEMMWB.
Anyone have comments on either of these...
(More)
Anyone have comments on either of these refrigerators? Thanks
Need a new refrigerator after only 8+ years from Kennmore -- have not been happy with this brand on...
(More)
Need a new refrigerator after only 8+ years from Kennmore -- have not been happy with this brand on the last 2 refrigerators. Would like a large capacity and efficient refrigerator with a reputable for being trouble free. Thanks.
I have the model with water only in door and icemaker. Neither are working. Water is hooked up and...
(More)
I have the model with water only in door and icemaker. Neither are working. Water is hooked up and flow is good. It worked great for a while but, overflowed so, I shut the icemaker off and it has never worked since. The water in the door has never really worked well. Any suggestions?
I have a newer (18) month old top freezer that is freezing up in the freezeer and making the bottom...
(More)
I have a newer (18) month old top freezer that is freezing up in the freezeer and making the bottom fridge not cool. If I unplug and thaw manually it will run fine for about 5 days then I have to run the manual defrost process again. I am quite handy, just don't know where to start. I assume the auto defrost function is not working properly???
I have a Kenmore Refrigerator model: 1065350300, the light and the unit turns on but in a Few second...
(More)
I have a Kenmore Refrigerator model: 1065350300, the light and the unit turns on but in a Few second it shutoff (you think is an electrical problem or compressor problem.
