Frigidaire GLTF2940ES Front Load Washer
Problem for Frigidaire GLTF2940ES Front Load Washer
My washing machine gets to the spin cycle and will
By selmel1018 on Jul 04, 2009
my washing machine gets to the spin cycle and will not drain. the message reads f03
Best Solution
posted on Jul 10, 2009
Very Helpful)
jabradshaw
Rank: Guru  Frigidaire Expert
Rating: 88%, 67 votes
The problem is probably the pump being clogged with an object. Typically it is a coin.
Remove the front bottom cover to access the pump. Remove the two hoses. Make sure you have a pan to catch the water from the hoses. You will be able to remove the objects after the hoses are removed.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Frigidaire GLTF2940ES Front
Questions and Unsolved Problems for Frigidaire GLTF2940ES Front
Do you recommend Frigidaire GLTF2940ES Front Load Washer?
Answer
Answer
the plastic fins inside my frigidaire front loader are trapping soose coins and a key i need inside... (More)
Answer
My washer will stop in mid cycle and then I have to push the start button again and it starts where... (More)
Answer
My almost new Frigidaire GLTF2940FS2 washer makes loud buzzing sound in the Permanent Press position... (More)
Answer
front loading Firdgeaire washing machinge has a lot of play front to back could. the drum is... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Washing... Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
