This sounds like an actuator. There is usually several (three or four) on different vehicles. There will be at least one that directs the air to different locations such as defrost. You also may have a defective selector switch. I would check this before I changed the actuator or blend door. If the blend door is defective, this usually calls for totally removing the entire dash panel and usually requires several hours work. If you have to have a repair shop do this it can be very expensive.
Your particular actuator will be a different one than they found.
They're all a absolute pain to get at because they can be well buried in the dash. I would start looking under the dash on the passenger side, that's where most of the air control is. Cannot get any air from dash vents while defrost and floor vents work fine...
Which vents, floor--defrost--dash? Can you hear the blower motor running? The squirrel cage could have broken loose from blower motor? There could be an actuator problem under the dash? If actuators are vacuum controlled and vacuum is lost, it might default to defrost, only blow out defrost vents.
Not sure what year, make or model vehicle is in question, but the issue is due to an actuator that has gone bad. Sometimes referred to as a mode actuator or blend door actuator. This actuator controls where air/heat will blow from (defroster vent, forward vents, floor vents or combo, etc.). Good luck. Ron @ Speed-O-Repair.
If you are referring to the air won't blow through the defrost vents or on the floor, you may have a stuck or broken blend door actuator. This part diverts air through the different settings: defrost, vent, floor etc. If you aren't getting warm or hot air regardless of the settings, you may either be low on coolant or have a bad thermostat.
Sounds like a faulty blend door actuator. This part diverts air from the different ports ie floor, vents, defrost. If it keeps changing when you hit a bump, either the actuator has a loose connection or it's bad all together.
