This problem should be removed because:
Problem with Microsoft Office Access 2003 (077-02871) for PC
My opening screen is linked to main table in db. I have set each field to locked so users won't edit in error. I added an "Add, Delete or Edit" button to open an almost identical screen
that can be edited. Both are bound to the same table. When the second form opens, no records show up, but the user can add a new record. I want it fully populated so the form can be used to edit existing records. I assumed that the problem was the other open form, so I added a macro that first closes the original form, then opens the editable version. Still no records. I can open it directly from the list of forms and it populates correctly. Data Entry is set to No and Recordset type is set to Dynaset. How to fix? Thanks
Solutions (1)
Change the "Data entry" Property to "No". This is what preventing you in viewing other records.
Ms Access - OpenRecordset question
Hi, I made the following recordset: Set rst = db.OpenRecordset(str_Query, dbOpenDynaset) This recordset will get me 30 fields. I want...
Export data in excel shld yoeet through VB
Hi, I want to execute the output of the folowing query SELECT IPADDRESS FROM TRANSFER_MANAGER I want ipaddress to be dispalyed in the 3rd...
crystal reports in vb 6.0
how can we create crystal reports in vb 6.0
Want to populate a form with data from a table,
Want to populate a form with data from a table, the Id number is keyed into the form and once it's matches with the Id in the table I...
Add Your Solution
Microsoft Access Report Creation
Creating a report in columnar form (details / titles down the left hand side). I want multiple columns to appear on the...
how to use validation rule
how to use validation rule in microsoft access?
what is the maximum number
what is the maximum number of records that Access 2003 can process in a query? I am finding that when I bring a large...
i wants download ms access
i wants download ms access 2003
See all Microsoft Office Access 2003 (077-02871) for PC Problems
Fix-O-Meter
17
17 people viewed this problem
- 0 people are following this problem. Be the first!
Top Microsoft Business and Productivity Software Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
