Question about Pentax ME Super 35mm SLR Camera
Shutter button does not trigger
This symptom came about after I rapidly went through two films while photographing fireworks last Monday. I noticed that the mirror was no longer raising when I was taking pictures midway through my third film, and there was no tension on the shutter button. The cock indicator was orange (cocked), but the film advance lever advanced freely.
Having opened the top and bottom covers (which is as far as I've felt confident to go so far, with thanks to, I've found that the shutter was not quite completely cocked, hence the free lever. Having manually thrown the internal cocking lever all the way ( the shutter is fully cocked, and the lever locks as normal. The shutter button still does not engage, but by prodding about with a screwdriver I am unreliably able to trigger the 'scissor' through the hole indicated in the picture. As it's touch and go to get this to happen, I haven't been able to observe the mirror raising/falling, but I think it does.
Can anyone give any ideas as to which part has died? I'd tend to expect that I've sheared or bent something inside, but I don't want to delve deeper until I'm in proximity to my soldering iron (to detach the wires necessary) and know what I'm aiming for.
With thanks in advance.
    An expert whose answer gotĀ voted for 100 times.
  • 206 Answers
Re: Shutter button does not trigger
The problem is actually the mirror box controlling mechanism and not the shutter it self ,strictly speaking. What is happening is that the locking /unlocking of mirror, when it is cocked, is gummed up by perished rubber bushings and rubber shock dumpers ( life span of 15-20 years max ) .
You need to get to the left hand side of the mirror box ( easy to locate once you take the m. box out ) and clean out with isopropanol ( can use benzine but is unhealthy ). Relatively easy but make a note of where the wiring goes ( shutter and l. meter ). And then also take care with the mirror box -cocking mechanism at the bottom ( draw picture of position before dismantling ).
Posted on Dec 05, 2007
0 characters
3 Points
Shutter release button on my F3 is stuck (locked) and shutter speed is locked at 1/60. Works fine when camera is attached to a motor drive, but not otherwise.
When the batteries in an F3 die, though the film can still be advanced, the photographer is limited to a single mechanical shutter speed of approximately 1/60 second. It is tripped by a secondary fully mechanical shutter release. Works fine when camera is attached to a motor drive because it uses the drivers power...Pls replace the batteries as one of the following is okay.....
  • Battery: Choice of one 3V lithium battery CR-1/3N type,,
  • two 1.55V silver-oxide batteries SR-44 type, or
  • two 1.5V alkaline batteries LR-44 type
Hope this helps!
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to continue f
or Helping out the Community :)
Jun 23, 2011 | Nikon F3 35mm Film Camera
Hi, I have taken over 20 rolls of film so far and haven't had a problem until now. Whenever, I go outside to take pictures (in the daylight), my pictures come out black (last 5 rolls of film) In the same...
I think the aperture is not shutting down to the opening you set it to. In an SLR, the aperture is normally fully open for viewing through the lens. When you press the button, the mirror flips up and the aperture closes to the figure you have set, then the shutter fires. If you have set a daytime aperture and the aperture sticks, you get a wide open aperture and an overexposed shot, but at night, you have set an open or almost open aperture anyway.
It is possible that the shutter is the problem, but the aperture is more likely to go wrong in my experience. It only takes a drop of oil on the blades. There ought to be a button or lever to shut the aperture down for depth of field preview which you could use to test this, or just look in the lens when the shutter fires to see if the aperture closes.
Nov 14, 2010 | Canon EOS-AE-1 35mm SLR Camera
Can't roll film for double exposure.
After taking the first shot, hold down the Multi-Exposure button while cocking the film-advance lever. This cocks the shutter without winding the film. You can continue to do this for as many exposures as you want. Just don't hold down the M-E button while cocking after the last exposure.
The Multi-Exposure button is the button on the front of the camera just below the shutter release button.
Apr 11, 2010 | Vivitar V3800N 35mm SLR Camera
Wont take photographs.
Try using the advance lever to complete a full stroke. You don't need film in the camera. It may just re-**** the shutter.
Jan 13, 2009 | Minolta X-370S 35mm SLR Camera
Pentax ME Super Shutter and Rapid Wind Button...
it could be the rubber bumper next to the fresnel lens has become sticky. very gently ( after removing lens ) try to bring mirror down without forcing it. it should release easily.
if not, rotate the select knob off auto. open film door and check that the shutter is fully deployed, shutters should not be overlapping.
remove screws from bottom cover and remove cover, keep camera up side down so that re-wind button stays put. there is a locking lever under the take up spool ( gray ) . with a pin move lever toward film door and bring advance lever fully to the right , then let it go so it returns quickly.
the shutter should have fired. if not the camera will need to be repaired. get an estimate first as there are no new parts available.
Dec 24, 2008 | Pentax ME Super 35mm SLR Camera
Film advance lever and shutter release button are "stuck"
No, it is not the battery. My guess is that the film leader did not stay in the take-up spool and is now bunched up around it. Try rewinding the film carefully as you normally would but remember that you are only rewinding a small portion of the length. You can even just open the film door and start over. You will only loose 3 or 4 frames on the roll.
Apr 27, 2008 | Nikon FE 35mm SLR Camera
Pentax ME shutter triggered just from advancing film
the shutter locking lever is sticking. time for a clean, lube & adjust.
i would take, or send this fine rugged camera to a reputable camera repair shop, have an estimate for a cla.
This model pentax is made with very little plastic and will last a long time with an occasional cla.
Apr 02, 2008 | Pentax ME Super 35mm SLR Camera
No shutter/film advance
with electronic cameras, it is the control circuitry. send it for service. your service agent probably will replace the complete pcb as they don't know or wouldn't care to diagnose which minor component went wrong.
Nov 15, 2007 | Contax ST 35mm SLR Camera
Bad picture developing
Since this happened on two seperate rolls of film, the problem may be that the shutter blades have been bent out of place.  This can cause the symptoms you describe.  Have a qualified technician look at the shutter.  Usually the blades can be reset.  In bad cases the blades may be bent or creased. If this is the case, the shutter may need to be replaced.
Oct 23, 2007 | Nikon N55 35mm SLR Camera
Pentax ME Super 35mm SLR Camera Logo
181 people viewed this question
Top Pentax 35mm SLR Cameras Experts
Bill Eager
Are you a Pentax 35mm SLR Camera Expert? Answer questions, earn points and help others
