Question about LG VX5300 Cellular Phone
Why does blue tooth connection drop off
Phone connects to Bluetooth then drops off and on every few minutes
SOURCE:
SOURCE: Bluetooth Problem
insde the phone setup for the bluetooth there is a mute function some phone have a mute button located on the edge so they can talk privately to someone else while holding a conversation about a problem etc also the headset has a mute button check that this has not been set in some way
Posted on Feb 18, 2008
sajwhat
  • 124 Answers
SOURCE: bluetooth
hey dude,
try changing ur visibility to "shown for all" mode.
If it doesnt work, mine email id is [email protected] and [email protected]!!!
Contact me.
Send me a feedback and rate my solution.
Dont forget to post a clarification request for ur problem after it is solved.
SAJAN([email protected]/[email protected])
Posted on May 11, 2008
SOURCE: blue tooth modem not working
I have RD8000 Lg mobile phone. it is connected through Bluetooth but able to send any data. It is not connected through USB with the computer.
Posted on Sep 17, 2008
SOURCE: my bluetooth and usb cable not working
LG:KU970:My bluetooth not working,Cannot send out file but can received via mobile phone
Posted on Dec 16, 2008
niquose
  • 198 Answers
SOURCE: LG KG290 Dial up problem
I have verified that your phone supports DUN Bluetooth profile so you should be able to use it as intended.
You need to verify though that your dongle supports DUN service profile. If it does, you may follow the instruction below for step-by-step guide:
http://www.pocketpccentral.net/help/wm_bluetooth_modem.htm
Posted on Jun 24, 2009
How do I pair speaker with phone
turn both phone bluetooth and speaker bluetooth off. then turn them back on. the speaker's light should be flashing indicating its searching for a device to pair with. as its flashing make sure your phones bluetooth is visible and searching. they will pair and your phone will tell you and the speakers light should quit flashiing and just remain on.
Oct 20, 2014 | Audio Players & Recorders
Bluetooth disconnects
If the phone is paired to anything else, this can happen. Unpair it from all other devices and try again.
Jan 31, 2014 | Polaroid GL10 Instant 3X4 Mobile Printer...
The Jabra A210 keeps dropping the connection between the devices.
My solution is to connect the jabra audio jack to the speaker output of my receiver. Jabra need it to detect a source. If the connection to the source is cut, jabra waits around 30 seconds and if nothing happend jabra stop the transmittion. I hope that helps.
Mar 13, 2009 | LG Jabra A210 Bluetooth Adapter for...
Bluetooth disconnects after 5 minutes
I know this sounds silly, but try having your cell phone more than a couple feet away from the base of the DECT phone. Bluetooth can have issues when they are really close together. I have mine setting about 6ft away without problems.
Jan 21, 2009 | GE Lands Phones
Phone to PC bluetooth connection fails
after pairing if you answer cell phone calls on cell, the bluetooth will drop....you must delete pairing and then add it back and remember to answer only on house phone while they are paired.....
Jan 19, 2009 | Nokia 6236i Cellular Phone
Problems getting bluetooth connection to stay on.
Your bluetooth is turned off.
Go into
MENU> SETTING> CONNECTIVITY> BLUETOOTH> STATUS (I THINK) ITS THE LAST OPTION> MAKE SURE THE MIDDLE OPTION IS NOT TURNED OFF.
Dec 26, 2008 | Motorola Mobility RAZR V3
CANT CONNECT BLUETOOTH TO MY PHONE
  • Start w/ power off (Best way to make sure you are off is to plug the headset into the charger for 1 minute, then unplug & wait 10 seconds before continuing.)
  • Press & hold MFB. DO NOT RELEASE YET.
  • light will flash quickly a few times to indicate power on. (Still holding MFB)
  • After a few more seconds of holding the MFB the light should glow steady.
  • Once the light is on steady you may release the MFB and pair with your phone.
good luck
Jan 02, 2008 | Motorola Mobility RAZR V3
Razr v3 bluetooth
all i can say by reading your issue is that , it would have to do with you being on the cycle and moving . but i will check on this for you.
Sep 19, 2007 | Motorola Mobility RAZR V3
LG VX5300 Cellular Phone Logo
Top LG Cell Phones Experts
William Norris
William Norris
MERCY GATHUA
Sheldon Dedek
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
