Question about Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum
Dirt cup lock on windtunnel vacuum won't lock
The lock that keeps the dirt cup (canister) in place will not slide to the lock position. It is only 1 month old. I have tried pushing up gently with dirt cup, tried repostioning the bottom of the dirt cup. Nothing seems to help. It seems stuck. A couple of times it worked with a little exerted effort so I thought it was just jammed or had dirt or somthing lodged in it. Now it will not go back to the locked position and I can not vacuum. I paid $300 and have had it 1 1/2 months. I am very frustrated now.
    President:
  • 1,673 Answers
It may have to be taken off and then re-installed, but if it is only 1 and 1/2 old, then it is under warranty. There is a full year on Hoover vacuums. Just take proof of purchase with you and take it to a warranty repair shop. You should have their 1-800 to call and find the closest shop. Warranties are void if you temper with it.
Posted on Jan 07, 2008
How do you empty it?
http://www.homedepot.com/catalog/pdfimages/e1/e1548aa7-3a91-42bc-b2c0-1b405ef54686.pdf
This owners manual shows you how to empty. If you dont have access to Internet:
1. Depress the dirt cup release button and pull nozzle away from unit.
2. Hold nozzle over a wastebasket, Grasp filter and gently pull out.
3. Shake excess dirt and debris out of dirt cup. Brush the dust and dirt off the filter or shake inside the wastebasket. IMPORTANT do not wash filter.
4. Gently push the filter back into the dirt cup.
5. To reattach dirt cup: Align bottom first and rotate nozzle up until it snaps into place.
Good luck.
Apr 20, 2016 | Dirt Devil Red Versa Power Stick Vac
My Hoover Elite Rewind just lost power while vacuuming and wont power back on?
Hi! It appears your thermal protector sensor has kicked in and caused your cleaner to power off. This is usually due to a clog or a filter that needs to be cleaned or replaced. Try these steps to get your vacuum back up & running!
1. Remove the dirt cup canister from the vacuum. Twist off the dirt cup lid.
2. Remove the primary foam filter. Hold filter under running water until water runs clear. Squeeze out the filter and allow 24 hours to air dry.
3. Slide the Hepa filter out. Tap the filter against the trash can until dirt stops falling. Replace the Hepa filter. (Do not wash)
4. Remove the hose from both ends. Use a broom stick to gently loosen and clear any clogs from hose.
5. Use a wooden spoon or something similar to loosen and remove any clogs from the lower hose.
Your vacuum should turn back on after it cools off, this can take up to an hour. Hope this helps!
Oct 07, 2014 | Hoover Vacuums
My Hoover Elite Rewind just lost power while vacuuming and won't power back on?
Hoover troubleshooting
Hello! The umbrella tube is a stationary part, it does not rotate. The dirt that enters in the dirt cup spins around the umbrella tube. If no dirt is entering into the dirt cup this can mean there is a blockage either in your hoses and/or your filters. Try these quick trouble shooting steps below.
2. Remove the primary foam filter. Hold filter under running water until water runs clear. Allow 24 hours to air dry. If the filter is really dirty it may need to be replaced.
5. Use a wooden spoon or something similar to loosen and remove any clogs from the lower hose. Hope this helps!
Aug 09, 2014 | Hoover Nano Cyclonic Compact Bagless...
Why does the thermal protection keep shutting the vacuum off?
1. Remove the dirt cup canister from the vacuum. Remove the dirt cup lid.
2. Remove the primary foam filter. Clean the filter as suggested by the owner's manual.
3. Slide the Hepa filter out. Tap the filter against the trash can until dirt stops falling. Replace the Hepa filter. (Do not wash) Filters should be replaced once a year.
Jun 28, 2014 | Hoover Vacuums
How do i clean canister of dirt devil featherlight bagless caniter vacuum
Hi there! To clean the canister or dirt cup, first remove the dirt cup from the vacuum. Twist off the dirt cup lid. Remove the pleated filter and empty the dirt cup. Tap the filter against the trash can until the dirt stops falling. If the filter is really dirty it may need to be replaced. The filter should be replaced every 6 months. I have included a link where you may go to purchase a replacement filter if needed.
Thanks! Hope this helps!
F1 HEPA Filter
May 18, 2014 | Dirt Devil Featherlite Bagless Vacuum...
How to empty it
1. Push down on carry handle and
pull dirt container away from unit.
2. Once it is pulled back lift it out.
3. Hold dirt container over trash can and push down on bottom
release lever to release debris.
4. Close bottom cover on the dirt
cup until it snaps shut.
While you have the dirt container out you can also clean the Lifetime HEPA filter. It is on the top of the dirt container.
1. Twist lid to the left to remove lid and filter from
container
2. Remove foam filter from dirt container and dump out
any loose dirt. Wash the foam filter.
3. Remove the HEPA filter by Twist filter handle to the left and
pull out of lid. Wash the Heap filter.
4. Once the filters are thoroughly dry (I recommend set out for 24 hours) then installer filters in lid and thread back on top of the dirt canister.
Before replacing the dirt canister you can also clean the exhaust filter install below the dirt canister on the top vacuum cleaner head.
1. Loosen the exhaust grille by pressing the locking tab, and
remove it.
2. Remove and shake out the exhaust filter and wash it.
Note: Scented filter are not washable.
3. Once the filters are thoroughly dry relace it and snap the
exhaust grill into place.
Replace the dirt container
NOTE: Dirt container will not
align on base if filter is not
aligned properly.
May 15, 2014 | VAX Appliances Vacuums
I just changed the belt an dthe vacumn doesn't have any suction.
Check the dirt canister lid and that the lock lever is in proper position
Oct 02, 2009 | Hoover U5753-900 WindTunnel Bagless...
Bissell easyvac filters
Replace Filter
As you vacuum, dirt and debris are deposited in the Dirt Cup
while air passes through the filter before being returned to
the room. This process enhances the vacuum path while
dramatically reducing dust, dirt, and potential allergens from
the air you breathe. Replacing the filter periodically enhances
vacuum power and air quality. To replace the filter:
1. Remove the Dirt Cup.
2. Grasp the filter frame and pull it straight from the Cup.
Empty the Cup.
3. Replace the filter. Push new filter into place at the top of the
Cup, place the small tab at the bottom of the Cup into the
slot at the bottom of the Canister cavity, then press the upper
portion of the Cup into place until the lock button snaps
into place. Use only BISSELL Style 6, #32047 Filters
[package of 2] in your BISSELL EASY VAC™ Model 3101-0.
4. EASY VAC™PLUS Model #3102-0 features a high efficiency
3M Filtrete™ Filter. To keep your cleaner operating at peak
efficiency and to remove irritating allergens from your
home, you should change the FILTRETE™ filter every six
months. Use only BISSELL Style 6, #32046 Filters [package
of 2]. The cup-shaped filter lifts out from the top of the
Dirt Cup, and the new one fits into place.
You may purchase these filters
by calling
BISSELL Consumer Services
1-800-237-7691
Monday - Friday 8 a.m. — 7 p.m. EST
Saturday 9 a.m. — 2 p.m. EST
or from the BISSELL website —
http://www.bissell.com
Jun 29, 2009 | Bissell 3102-0 EasyVac Upright Vacuum
I have a hoover windtunnel bagless that the filter fell out of on accident when I was trying to dump it and I can't figure out how to put it back in
Hi, You don't say which model windtunnel you have but most are the same. The canister is in two sections with a Hoover emblem to the right of the handle. this is the side the filter goes on. The bracket slides out and holds the round filter, the round filter snaps into the bracket so that the end of the filter with the opening goes down to fit the hole in the bottom of the canister. When putting the canister back in the vacuum be sure the top goes back flat on the canister and the locking lever is open all the way. You have to slide the canister back in level and then it will drop down into position you can't tilt it. now you can lock it. Good Luck!
Jan 29, 2009 | Hoover Ultra U6430-900 WindTunnel Bagged...
Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum Logo
332 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
