Question about Goodman GMS90703BXA Heater
Goodman heater where is the filter?  cool air comes out unless i put the thermostat on 70.....on the thermostat the word filter is on it .....but we can't find the filter
  • 1,420 Answers
Depending upon your installation the filter could be located in the bottom section of the furnace right or left of the blower, remotely located in its own housing in the return air plenum or it may be missing altogether. If you can find a spot to put one in, do it. You may just have to reset your thermostat. Some models have a pre-timed indicator that comes on after a number of hours reminding you to check your air filter. Post the model number of the thermostat and maybe we can help you reset the timer.
Posted on Nov 12, 2007
Goodman GNP075-3 seems to work fine but air coming out is only about 46 degrees
Check to see if the return duct has come apart in the attic or in the crawlspace (wherever the return is connected)
Jan 01, 2014 | Heating & Cooling
Air handler fan cuts on runs a few minutes and then cuts although thermostat is set to off.
your thermostat could be wired in to a energy recovery venilator which will bring the unit on for a certain amount of time every hour some thermostats have recirculate mode which will do the same thing to help filter the air
Apr 16, 2013 | Goodman Heating & Cooling
Goodman GS9 blowing air but not getting hot
Does furnace fire up ,if not you have a issue with your furnace and not thermostat
Feb 12, 2018 | Goodman GMS90703BXA Heater
My girlfriend has a forced air Goodman furnace in her house. Her furnace has been not running well. Whenever the filter gets dirty the furnace does not run right which it to be expected. The problem is...
where is the thermostat located? i should be on a inside wall in a comon room and not around lights, computer or heat vent or air return. a thermostat is just a switch and will operate in its enviroment. does the fan cycle off before the heat starts blowing again? the fan on these are on a timer that the t stat will have to "brake" open on reaching temp to shut off. not knowing where your at look this over and i hope it helps. i dont think i would let someone sell me a control board for this problem.
Feb 08, 2011 | Goodman GMS90703BXA Heater
My Honeywell AC unit doesn't seem to be working properly. It will not retain a temperature. I set the thermostat to hold a temperature of 70 degrees. Room temp still reads 74 degrees. Something is working,...
The frost on the pipe indicates you have a dirty filter, dirty evaporator coil, Blower not running at the proper speed (to slow) or you are low on refrigerant.
Jun 29, 2010 | Heating & Cooling
Goodman with 2 thermostats, freezes in summer, no heat in winter
is the system zoned? if so maybe the zoning control board to the damper motor is wired improperly. when a system freezez its because of 1- restricted air flow across coil, (maybe dirty filter) or 2-low refrigerant charge. again could depend on how its zoned.
Feb 16, 2009 | Goodman PHKJ048-1 Air Conditioner
AIR or Heat wont come on/ goodman GMP075-3
If there is no blinking light, then the unit is not seeing a call for heat or cool. My guess is a lose or broken wire in the thermostat circuit. Try and putting a jumper across the red and white heat terminals inside the furnace and manually closing the door switch. If you get heat, it's telling you there is a wiring issue. If you get nothing, it's a bad circuit board.
Jun 08, 2008 | Goodman GMS90703BXA Heater
The heat works perfect but when I call for air it does not do anything
Make sure that the thermostat is on Cool and that the outdoor electrical disconnect is on. If you still do not get cooling, there may be a fuse that needs replacing or other issues.
May 16, 2008 | Goodman GMS90703BXA Heater
Goodman GMS90703BXA Heater Logo
104 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
