Home | U-Line | Icemaker | Uline icemaker com...
U-Line Icemaker
Problem for U-Line Icemaker
Uline icemaker compressor runs very hot - slow ice production
By elsj on Jul 04, 2009
uline model bi-98
will make ice for 12 hrs but compressor gets very hot and ice production is very slow
Solution #1
posted on Jul 07, 2009
Not Rated)
admiralstopf
Rank: Guru
Rating: 91%, 81 votes
if the ice production is slow first try to set it on a warmer temperature. Now if its frosted up then you will need to defrost it. Also check the fan to see if its running. if yes is the condensor clean? If yes then check temperature in bucket. 10 to 15 degrees is ideal for this model.
Was this helpful?
Yes
No
Popular Solutions for U-Line Icemaker
Questions and Unsolved Problems for U-Line Icemaker
Do you recommend U-Line Icemaker?
Answer
Answer
The motor was locking up and I took it apart and fixed it and runs great when hooked up to 120 but... (More)
Answer
Icing up in the bottom of the tray compartment, as if it is leaking water from the supply, still... (More)
Answer
10 e flashing no ice produced.
Answer
Won't make ice -- water supply works for a while and then quits. Water pump has been replaced.
Answer
Does not get power from feed linechecked power line and all is good. Cleaned and drained entire... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For U-Line Icemaker:
Top Refrigerator Experts
Rank: Guru Guru
Solutions: 1494
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Refrigerator Experts
Top Refrigerator Repair
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(816) 471-5334
* Please Contact us for More Information
At Your Service Appliance Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
