Question about Microsoft Xbox 360 Console
XBOX ( not a 360 )
When we try to play. It tells us to conecct the dvd playback kit reciver.
    An expert who has written 3 tips or uploaded 2 video tips.
  • 116 Answers
Re: XBOX ( not a 360 )
What are you trying to play, DVD movie or a Xbox game?
Posted on Nov 16, 2007
0 characters
3 Points
I lost may xbox playback kit remote control what can i use as an alternative
You can use your Xbox controller as a remote control to watch media.
Here are the actions for each button:
To... Press... Play or pause Note If the DVD is bookmarked, it will start playing automatically where it was stopped the last time you viewed it. START Skip back one chapter LB
A, then select skip back Skip forward one chapter RB
A, then select skip forward Fast forward RT Rewind LT Page up through a list of items. RT Page down through a list of items. LT Open the on-screen display for more advanced playback controls. X, Y
May 02, 2011 | Microsoft Xbox Console
Xbox 360 - Please put disc into an xbox 360 console to play
Try getting a disc drive cleaner. (Maxwell). is and example retailer.
May 24, 2010 | Microsoft Xbox 360 Console
When i put an Xbox 360 game in it tries to play it as a DVD movie. please help!!!
When you try to play a DVD movie or an Xbox 360 game disc on your Xbox 360 console, you may receive an error message. This article presents step-by-step guidance to help you determine whether your disc is playable.
SYMPTOMS When you try to play a disc, you may receive the following error message: Can’t read this DVD.
CAUSE The DVD or game disc may be dirty or damaged. Because the console cannot read the disc well, it may even mistake a game disc for a DVD and report this error. If this problem occurs with multiple discs, even clean and undamaged discs, there may be a problem with your Xbox 360 console.
Note If you receive a different error message, such as one of the following messages, the problem is a different problem:
Error message 1 Can't play DVD. Wrong region code. Error message 2 Can’t play DVD. Family settings restrict playback of this DVD. If you receive one of these error messages, see the corresponding Knowledge Base article: 907620 While attempting to play a standard DVD movie using your Xbox 360 console, you receive the error message: "Can't play DVD. Wrong region code" 908645 While attempting to play a DVD movie using your Xbox 360 console, you receive the error message: "Can’t play DVD. Family settings restrict playback of this DVD"
THINGS TO TRY Here are some things that you can do to try to fix the problem or to determine what caused it.
Determine whether the disc is dirty or damaged Discs that are smudged, scratched, or otherwise damaged cannot be read by the Xbox 360 console. You will want to examine the disc to see whether it has smudges, scratches, or other damage. To do this, follow these steps: 1. Examine the disc for dirt or damage: a. Pick up the disc by its edges. Do not touch the top or bottom surface. b. Examine the shiny side of the disc to make sure that the disc is clean and has no damage.
NoteScratches that follow the curve of the disc are very damaging and prevent a disc from being read. If your disc has even one of these kinds of scratches, the disc is damaged, and you will no longer be able to play it. If this is the case, see step 4. 2. If the disc is dirty, clean the disc by hand: • Use a soft, clean, dry, chemical-free cloth to clean the disc. • Lightly wipe from the center of the disc outward. 3. After you clean the disc, try to load it in the Xbox 360 console. If the disc still will not load or you receive the same error message, the disc is damaged, and you will no longer be able to play it. If this is the case, see step 4. 4. If the disc is damaged, do one of the following: • Because DVD discs are not game discs and the disc was damaged because of misuse of some type, such as not storing the disc in its case, the only thing that you can do is buy a new one. • If you feel that the disc was damaged by the Xbox 360 console in some way, please contact Xbox Customer Support. To do this, please visit the following Microsoft Web site:
Feb 18, 2010 | Microsoft Xbox 360 Console
Xbox 360 Freezing during netflix and dvd playback
If you are using a HDMI connection, often the connection will be lost between your xbox and your tv. In my case I simply change to another channel or the other HDMI channel and then back and the secure HDMI connection will be restored.
Aug 05, 2009 | Microsoft Xbox 360 Console
Wat do i do if my xbox tells me to play dvd when i
try standing it up then try the game then set it down again and try the game repeat
Jun 22, 2009 | Microsoft Xbox 360 Console
My xbox 360 wont play my games
if it tells you the disc is unreadable then the laser maybe bad or dirty.
try a cd lens cleaner and see if it solves the problem. if it doesn't then your dvd rom will need to be replaced
Apr 21, 2009 | Microsoft Xbox 360 Console
What would be the dvd playback kit be..? Because I wanted to see if my dvd will play on xbox but as i am doing that it's telling me to connect the dvd payer kit to the xbox..i am not sure if i completely...
Assuming you have an original, unmodded Xbox, you will need the DVD playback kit (gamestop). You can find it here:
for much cheaper than anywere I've seen before.
if you have a modded xbox, search for the xbmc package from t3ch. This will allow you play most video formats including DVD.
good luck,
Feb 17, 2009 | Microsoft Xbox Console
Playing dvd's at 1080 resolution with xbox 360
The 360 will upconvert DVDs to 1080P only through a VGA cable or an HDMI cable.
Dec 11, 2008 | Microsoft Xbox 360 Console
Won't play a dvd
Go to a local video game store, i.e. GameStop or Best Buy and see if you can pick one of these up. I don't know who carries them new anymore, but GameStop or some used game store should have them. I think they run about $15 new or $10 used. I keep mine plugged into the 4th controller port so I never have to take it out. It'll work just fine once it's in there.
Oct 04, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
79 people viewed this question
Top Microsoft Video Game Consoles Experts
Troy Gorman
Troy Gorman
Pablo Gonzalez
Martin Murray
Are you a Microsoft Video Game Console Expert? Answer questions, earn points and help others
