Dometic 57915.531 Air Conditioner
Problem for Dometic 57915.531 Air Conditioner
Dometic 57915.531 Air Conditioner Blows 3 amp fuse in control box
By autopilots on Jul 04, 2009
2008 Salem 26TBss worked fine when parked adn returned to find unit would not power on. No manual fan operation either.
Found fuse under cover that keeps blowing the 3 amp fuse.
Any Ideas ?
And thank you for your time.
Steve
Solution #1
posted on Jul 04, 2009
Not Rated)
jeffmyers_20
Rank: Guru
Rating: 96%, 66 votes
Steve,
The three amp fuse is installed in the board to protect from shorts or overloads created by disconnecting or reconnecting components when DC power is still connected to the system. If the fuse is blowing, then you more than likely have a short in the 12VDC system between the control unit and the thermostat.
1. Pull the cover off of thermostat and remove the +12 (or +7.5 depending on the model) wire. Access the other end of the wire in the AC compartment. Using an ohmmeter, touch the end of the wire at the AC with one lead and touch the control box with the other (or any ground source). If you get a reading other than OL or Infinity, then that wire is shorted out in the wall somewhere. If not, repeat the steps for the rest of wires except the ground of course. If all of these wires appear to be fine, you may need to take it in for some more extensive troubleshooting.
Hope this helps,
Jeff
Please rate me!!
Was this helpful?
Yes
No
Popular Solutions for Dometic 57915.531 Air
Questions and Unsolved Problems for Dometic 57915.531 Air
Do you recommend Dometic 57915.531 Air Conditioner?
Answer
Answer
I have 1980 rrgf rooftop unit rrgf -series, the heater takes long time to quick in some times it... (More)
Answer
The ignitor lights up, but the pilot light doesn't light. I know it isn't a gas problem within the... (More)
Answer
i have a pioneer air con ducted model no:ps11. i neen the cap sizes as the old ones dont have a... (More)
Answer
Hi, My Fujitsu airconditioner turns on by remote but it doesnt blow cold air.Its a dual hook up... (More)
Answer
The unit is leaking water but i dont know where the drain is to unblock it
Describe your Air Conditioners problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Air Conditioner Experts
Top Air Conditioner Repairmen
in , IL
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
