Question about Pioneer DEH-1100 CD Player
Pioneer cd radio deh-11 clock set
Need to set clock
  • 2 more comments
  • Anonymous Nov 20, 2007
    need instructions
  • msp123 Nov 29, 2007
    How do you set the clock?
  • FLIP FLOP Nov 29, 2007
    can not set time on radio
  • Anonymous Sep 29, 2008
    how to set clock on supertuner II
  • 1,512 Answers
For most Pioneer single CD players, you can set the clock using the following steps:
  1. Press and hold the SOURCE button until the unit shuts off.
  2. Press and hold SOURCE again until the clock appears. With some models you will press and hold the FUNCTION or AUDIO button instead of the SOURCE button.
  3. Press the left or right arrow to select the segment of time you wish to adjust.
  4. Press the up or down arrows to increase or decrease the numbers in the blinking segment.
  5. Once the clock is set correctly, press the SOURCE button to exit.
Posted on Apr 11, 2008
  • 626 Answers
Here ya go;
Posted on Nov 10, 2007
    Problem Solver:
  • 5 Answers
THANK YOU Robotek ! I set it immediately and before your help I had tried time and time again. You're the man !
Posted on May 27, 2008
3 Suggested Answers
shawnsz
  • 64 Answers
SOURCE: pioneer DEH-P500UB set the clock
1 Press SRC and hold until the unit turns
off.
2 Press MULTI-CONTROL and hold until
CLOCK SET appears in the display.
3 Turn MULTI-CONTROL to select clock set.
1 Use MULTI-CONTROL to select
CLOCK SET.
2 Press MULTI-CONTROL to display the
setting mode.
# Press BACK to return to the previous display.
3 Press MULTI-CONTROL to select the segment
of the clock display you wish to set.
Each time you press MULTI-CONTROL, one
segment of the clock display is selected.
Hour—Minute
As you select segments of the clock display,
the selected segment blinks.
4 Turn MULTI-CONTROL to put a clock
right.
# You can also perform the same operations by
pushing MULTI-CONTROL up or down.
Posted on Feb 18, 2009
ZJLimited
  • 17970 Answers
SOURCE: i need to set the
This info is from DEH-2400F User Manual (pdf)...
Hope this helps (remember to rte and comment this).
Posted on Jul 16, 2011
How do I change clock in 2007 Mazda r
Hold Clock to get it in the set 12/24, tap Set to move to 12hr, tap clock to move to the hour, tap set to get to the right hour, tap clock to move to the minute, tap set to get it to the right minute, tap clock to back out of it.
Mar 09, 2015 | Mazda Cars & Trucks
How do I set the alarm on my Sharp Accu-Set Model SPC452?
  • 1 Insert batteries into your atomic clock. Without these the clock won't work. The number of batteries required depends on the clock. There is usually a panel on the back of the clock where you can insert the batteries.
  • 2 Set the clock. Usually, this is done automatically, as the clock will seek out and receive the signal within 6 to 8 minutes. If this doesn't happen, you'll need to do it yourself. Hold down the "Set" button. A figure on the clock will start blinking. Adjust this by pressing the adjustment button. Press "Set" again to go to a new time. Continue until the clock is properly set. No matter what you put time you put in manually, the clock should adjust to the atomic setting within 48 hours.
  • 3 Set the time zone on your atomic clock. How to do this depends on your specific clock. On some, there is a time zone slider; you simply slide it to your time zone. Otherwise, you will need to enter the manual mode you used to set the clock. Switch the mode until the time zone starts blinking. Now, adjust until your current time zone is selected. If it goes by Greenwich Mean Time (GMT), the time zones in the United States are -5 for Eastern time, -6 for Central, -7 for Mountain, and -8 for Pacific.
  • Read more : http://www.ehow.com/how_6403731_instructions-time-zone-atomic-clock.html
    Jan 29, 2015 | Audio Players & Recorders
    I need to set the clock on a pioneer cd/radio DEH-2400F
    Jul 16, 2011 | Pioneer DEH-2400F CD Player
    Need to set clock on oven
    Instructions
      • 1
        Check the oven to ensure that it is off and that the timer isn't running. The buttons used to set the clock are the same buttons that adjust the oven, and you may end up making unintended adjustments to the oven.
      • 2
        Press the "Clock" button to enter the clock setting mode. The LCD will show the current time set on the oven.
      • 3
        Use the "Set Temp/Time +" or "Set Temp/Time -" buttons to adjust the clock to the current time. Depending on your model of stove you may need to use the "Hour," "Min" or the "Temp/Hour" up and down arrow buttons to set the time.
      • 4
        Save the new clock setting by pressing the "Start" button. Depending on your stove model, you may need to press the "Clock" button a second time if the "Start" button does not work.
    Read more: How to Set the Clock on a Whirl Pool Stove ' eHow.com http://www.ehow.com/how_5692616_set-clock-whirl-pool-stove.html#ixzz1H3Wfexf6
    Mar 19, 2011 | Ovens
    I need to know how to set the clock on my pioneer car cd player model DEH-P4000UB.
    Try this with your key in the on position and the radio off. Hit the clock button. When the clock appears, hold the clock and audio button at the same time. Thats the way my pioneer does it.
    Oct 07, 2010 | Pioneer DEH-P4000UB CD Player
    Set clock on car radio.
    Here is a link to the owner's manual for the stereo which will tell you how to set the time:
    http://a248.e.akamai.net/pix.crutchfield.com/Manuals/130/130DEH1800.PDF
    May 22, 2010 | Pioneer DEH-1800 CD Player
    Can't set clock
    1. Power the unit off (See instruction manual page 11, "Power ON/OFF") - Crucial missing instruction.
    2. Use MULTI-CONTROL to select CLOCK SET. 3. Press MULTI_CONTROL to display the setting mode. 4. Press MULTI-CONTROL to select the segment of the clock display you wish to set. 5. Turn MULTI-CONTROL to put a clock right
    May 17, 2009 | Pioneer DEH-P4000UB CD Player
    CANNOT RESET CLOCK
    1) Press SOURCE and hold it until the unit turns off.
    2) Press AUDIO and hold until clock appears in the display.
    3) Press AUDIO again to display the setting u need to configure.
    - when u found clock, press < or > to select the segment of the clock display you wish to set.
    - press /\ or \/ to set the clock.
    - press BAND or hold AUDIO when finish.
    YBC (/\)
    Apr 27, 2009 | Car Audio & Video
    I NEED THE INSTRUCTIONS ON HOW TO SET THE CLOCK ON MY MICROWAVE
    To set the time just press CLOCK, then press CANCEL, then enter new time setting and press CLOCK again.
    Apr 07, 2009 | Microwave Ovens
    Pioneer DEH-1100 CD Player Logo
    5,296 people viewed this question
    Top Pioneer Car Audio & Video Experts
    Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
