How do I change the receiver from CDs to a radio station?
The receiver was on something like "Rock Concert", I only have played the Cd's on it, and I tried to change it to a radio station and now I cant get either. I lost the manual
did you wire it yourself? if you did make sure you wired the cd player in properly just like you wired the radio. if you got a shop to do it just take it back to them
OK you have mistaken this player for a player you can plug in an MP3 Player into .....This is an MP3 player that plays MP3 CDs you burn off your PC ... so it will only play MP3 CDs!!! about search problem I don't have a fix but just manually adjust stations then program them to your buttons.
i'm not familar with that particular radio.... but try unhooking the battery for about ten minutes then hook the battery up again.... it should be fine.
Clean the lens. Use only a special CD lens cleaner and follow the instructions carefully. If that seems intact, (and you feel comfortable doing it) check the traverse assembly (the metal rod that the laser travels along
and the gear that drives it) if CDs aren't recognized or won't play,
frequent skipping occurs at random, CDs randomly get stuck in one spot,
the player can't find tracks correctly, or cleaning the lens doesn't
work. Dust and lint may be interrupting its function.
If that doesn't work then have the laser-head assembly checked by a repair person if the traverse
assembly seems intact and free of debris.
Mabye. I would suggest either opening the unit up and cleaning thr "laser" (optical pickup) with a q-tip. Or try using one of those cleaning cds that have the little cleaner fabric on the inderside...
if that doesent work something is most like wrong with the cd machanism wether its not spinning the cd or just not reading it due to a defective laser..
ampman!
