Question about EliteGroup 915G-M Motherboard
PCI-express won't come up.
I installed my 915G-M board with my SB-live card and a PCI-express nvidia 8500GT 512mb graphics card.
The sound card will not work, Drivers install ok, and it registers as operational in the system devices. It just crackles when I try to play sound through it. I removed it and enabled onboard sound for now. I'll tackle that problem later.
My big concern is that my Video card is not recognized. My monitor is connected through the graphics port on my PCI-E card and it displays at 32 bit 1280x1024, but its dog slow. I checked the video settings and it says that it is using the onboard graphics processor. In the device manager under system resources, the PCI-E bus has a yellow "!" next to it and it says its resources are all conflicting with the onboard graphics processor. There is no where in the CMOS to disable onboard graphics and if I disable the device in windows it no longer boots. If I boot in safe mode or VGA mode I just get a black screen. I restored to last good setting and it comes up again with the PCI-E card conflicting and unused. The drivers for it are loaded and installed, but the card is not present in the device manager. Please help!
  • Baratacus Nov 12, 2007
    I didn't mention it, but I already tried enabling and disabling the audio and vido from the bios. The video won't even come up without the peg enabled since i can't seem to get a video signal through the onboard graphics port. It will run the onboard video signal through the PEG board, but it won't actually recognize the PEG as its own graphics display device.
    The sound card issue was with the onboard audio disabled as well. I couldn't even get static from the soundblaster with the onboard audio enabled. At least the onboard audio works through its own ports though.
  • Baratacus Nov 18, 2007
    went to the website and downloaded the new bios and the bios flash program. I flashed the bios and it solved the problem. Apparently theres a problem with the old bios recognizing the pci card as well as problems with using add on sound cards. Thanks for the help peepnklown.
  • 175 Answers
BIOS Setup Utility; go to Advance Chipset Features
PEG Port is your PCI-EXPRESS…Enable/Disable
Posted on Nov 11, 2007
  • Frank
    Frank Nov 11, 2007
    You can also Enable/Disable the onboard AUDIO in the same TAB; disable the onboard and install the SoundBlaster.
  • Frank
    Frank Nov 11, 2007
    http://www.ecsusa.com/ECSWebSite/Support...
    PRODUCT: MOTHERBOARD; SOCKET 775; 915G-M
    I found all of that information from downloading the manual; plus you get can BIOS/DRIVERS also.
Intel 945 gccr has pci x16 slot for graphic card or not
The Intel 945GC Express Chipset contains two separate, mutually exclusive graphics
options. Either the integrated Intel GMA 950 graphics controller is used or a PCI
Express x16 add-in card can be used. When a PCI Express x16 add-in card is
installed, the Intel GMA 950 graphics controller is disabled.
The 9500 should work even though it is pci-e 2.0..i would go with a brand like BFG as they offer a lifetime warrantee..
Regards..
Apr 02, 2010 | Intel Motherboard
Please give the list of compatible graphic card for this motherboard
Hi !
You can try this video card NVIDIA GeForce 8500GT 512MB PCI-Express x16 Video Card . It is compatible with that motherboard.
Thanks
Dec 26, 2009 | Intel D945GCCR Motherboard
I have an Asus 128mg EAX300 card installed on D915GAG. Whenever I try to install a new graphics card (http://support.intel.com/support/motherboards/desktop/sb/cs-022225.htm) I receive the error 'no...
According to the specs of the MSI 9400gt 512mb HDMI graphics cards, its system requirements are:
1. PCI Express or PCI Express 2.0 - compliant motherboard with one x16 graphics slot.
2. Power supply of 300 (and up) watt is highly recommended for system stability.
Please refer to this article:
http://www.intel.com/support/motherboards/desktop/sb/CS-012073.htm
Also, if possible, try to install your new graphics card into another computer & see if it will work fine or not.
Jul 09, 2009 | Intel D915GAG Socket 775 Motherboard -...
More compatibility problems ?
what you will need to do is accertain which cpu format you have in your machine and find out if you have pcie 1 or 2
regards rich
Feb 24, 2009 | Dell Dimension 9100 PC Desktop
Freezing up
Also,go to the games web sight and look for compatibility issues .
Jun 12, 2008 | Computers & Internet
Installing NVidia 8500GT XFX 256MB graphics to A8N-VM Motherboard
The chances are that you have an old motherboard which is not compatable with the new graphic card. Or you may be running windows 98 and are downloading the driver for xp or visa versa. The probable solution, will be to sell the new card on ebay and buy the best old card you can off ebay. Or just make do with the card you already had in your computer. If you are determined to have a better graphics card. A motherboard upgrade with better graphic card may be the best answer or buy a better spec pc second hand if you don't have much money. You'll probably waiste a lot of time trying to get the new card to work and it probably never will.
Jan 28, 2008 | ASUS A8N-VM Motherboard
EliteGroup 915G-M Motherboard Logo
315 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
