I have been trying to turn on my new kocaso M9209. 4.2. 9 inch I got it yesterday in the mail. The instructions were to allow it to charge on charger for 4 hours and then press the on button for 5 seconds or so and when it comes on stop pushing. Well I press the on button and nothing happens. Fix ya says to do what I've already completed to no avail. I even tried using another charger I had for an other tablet and there was no change. Is there something wrong with the unit? Or is there something else I can try?
SOURCE: My galaxy tablet was fine
You can damage the battery but it is very rare to actually do that. What you need to do is plug it in to the wall charger and leave it alone over night. At that point it should be just fine. it will actually start to show some signs of life after a few hours but don't be tempted to do anything wih it. it will first show a charge light or something after maybe 40 minutes if it is a faster charger.
If it shows no life the next day then you can try charging again but at this point you may hae a problem that requires either a battery replacement or warrenty. The battery has a microcontroller on it and when the battey gets real low they do not behave that well and typically you get the stone dead brick behaviour. And most people do not let it charge long enough to get it working. It is possible that there are other problems but those are usually moore serious and require replacement of the unit. The battery can be replaced but requires the etire case to be disassembled.
So charge it then check your warrenty and it may need serious repairs or to be replaced. If it is out of warrenty then you need to be careful on the cost verses replaceemn
