SOURCE: Need Sound Card Driver (Compaq Presario C700)
hi firend
here is link
Audio driver from the link below .
Conexant CX20549-12 High Definition Audio driver:
ftp://ftp.hp.com/pub/softpaq/sp35501-36000/sp35940.exe
Do not click on the link. Please copy the link and paste the link at the
address bar of the browser. Next hit the enter key.
k
Installing this driver may result in an error. But continue with the
following steps to get the audio driver installed correctly.
1. Click on Start and select Run. Now type devmgmt.msc and press enter.
2. Right click on "AUDIO DEVICE ON HIGH DEFINATION BUS " or Conexant
High
defination audio entry and click Update driver.
3. Select "Install from a list or specific location"
4. Click Next. Then select "Don't search, I will choose the driver to
install"
5. Click Next and then select "Sound, video and game controller" from
the
list.
6. Click Next and then click Have Disk.
7. Click Browse C:\swsetup\sp35940 folder and the double click the
(WinxP -> Thrifty10 -> CPL30A5a.inf file for Audio) Select the .inf file,
click open and Continue with the onscreen instructions.
Similarly install Modem Driver:
SOURCE: download sound driver for compaq presario c700 with product number GS096PA#ACJ
i want sound driver for compaq presario C700 laptop
model no C734TU
This steps only for compaq presario c700.....
don't update your laptop.....kindly turn off all windows update...
uninstall
all audio, hd modem, and UAA bux driver for high defination driver in
system device....restart your lpatop..go to hp.com and search following
no. for modem driver-(sp33442), for audio driver(sp35270), for UAA
driver (sp32395), download and install...
and install drivers follow these steps:
Open device manager and right-click on Audio device on High definition Audio Bus.
Select Install from a list of specific location (Advanced) Click Next
Select Don’t Search. I will choose the driver to install.
Select Sound, Game & video controller from the list of Hardware type
Click on Have Disk
Click on Browse and navigate to C:swsetupsp35270 and click on .ini file OK
Click Next
It will give you an update driver warning message. Click on yes.
It will start installing the driver
Click on Finish..
follow these steps to all drivers install.
bye,,,,,,,,,,
SOURCE: Compaq Presario C700 series C794WU Laptop audio driver for windows xp
hi sir i have need presario c700 series audio driver
because my audio driver unstall by mistake
plz avlable this driver winxp
i have compaq presario c700 laptop how do i find my sound driver ?
Click on
Start, Run, and type regedit and press
Enter
Click on the plus signs (+)
next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder
is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the
following names in the right hand column.
Upper
Filters
Lower
Filters
Upper
Filters.bak
Lower
Filters.bak
If any of the above keys shown in step
4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and
check to see if your CD or DVD drives have returned. You may also want to open
Device Manager and verify that the yellow exclamation and error code on the CD
or DVD drive is gone. Hope this
helps
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
