I bought the smart book at a swap meet but cat do anything with it because windows CE requires a password that I do not have.
SOURCE: I can't remember my administrative
TRY TO BOOT IN SAFE MODE IF POSSIBLE OR THERE SHOULD BE A RESET BUTTON ON THE PC TRY THAT BUT BE CAREFULL U MAY LOOSE ALL UR DATA ON THE PC
SOURCE: net book with windows ce6.0 powers up , screen
Have you tried resetting the machine?
Turn the machine over, on the bottom about 1 inch to the right of the lower rightcorner of the data plate decal is a tiny hole labled RESET. You have to insert a small object (toothpick) into the hole and depress the switch and hold it for a few seconds, then try to allow it to boot again
SOURCE: The netbook is using Windows CE 6.0 how do I
If this is the SYNET07526, then you cannot change it to Win 7. You are stuck with CE and the installed software unless you just want to experiment. See my TIP at http://www.fixya.com/support/r7350901-fix_synet07526_wifi_flashing
SOURCE: Product: Sylvania Netbook (SyNet7WID).
Hello, from what I understand, the netbook doesn't use an Intel-standard processor, so only code specifically for that chip will run, ie, no downloadable plug-ins,java, flash etc. CE itself is based on windows 98. I found a site giving useful overviews on these netbooks, I think they're worth visiting:
tp://bestgadgetnow.co.uk/gadget-news/99-cvs-sylvania-netbook-computer-review/
just don't try to view it on your netbook!
regards,
nicam49
SOURCE: reset the password for windows
If this is a SYNET07526 using Win CE, then you will have to re-flash the system in order to get rid of the password that you have forgotten. See my TIP for flashing the SYNET07526 at: http://www.fixya.com/support/r7350901-fix_synet07526_wifi_flashing
