Question about Maytag Atlantis MAV6260AWW Top Load Washer
Maytag washing machine #mav6260aw
I have a 3-4 year old maytag atlantis washer. Sounds like the bearings are out.....terrible squeaking sound during spin cycle....will not completely wring out clothes......still wet,though water drains from tub. Will try to look for oil (transmission) under machine. Is this worth the trouble or should I just look for new machine?
  • 2 more comments
  • icrums Sep 10, 2008
    started squealing at start of spin cycle no only makes a loud bumping sound and does not spin at all.
  • Anonymous Sep 25, 2008
    same as urs
  • raiderteam1 Feb 27, 2009
    Squealing sound when in wash mode. Clothes do not get rung out enough. I'm sure it's the bearing below the main drum, but don't have a diagram to check for the proper part number.Can someone help with this problem?
  • Johnkim Mar 07, 2009
    Same squealing sound, I have disassembled all parts myself, I could not find any problem, so, cleaned, sprayed WD40, the sound has gone for a while, but after a month, the motor was burned.
I found the crazy sound where comes from, it was an aluminum ring in the drain pump.
First of all, I took out the belt under the bottom, checked moter to run itself, it was fine, so, I suspected some waste in somewhere, it was lucky I disassembled the drain pump first, no waste in the drain pump, but I saw a ring that was cut under the pump (seems should be connected), when I try to spin the pump wheel by hand it is broken because of the ring.
I ordered the entire drain pump on the website, the cost $74 + delivery fee, I recognized Maytag re-designed the drain pump due to the ring ( new pump does not have the ring anymore). Now the washer works fine like new.
Posted on Mar 11, 2009
  • Maytag Master
  • 1,211 Answers
If you are a good DYI'er you can find the parts here http://www.repairclinic.com/0003.asp you'll need a couple of hours set aside and maybe a few beers for after. If you are not going to fix it yourself the labor costs and parts would come
to just about the price of a new one. Hope this helps.
Posted on Nov 11, 2007
Loud noise during spin cycle
Yes unfortunately. but it's not terribly difficult to do. There are many how-to videos online
Mar 16, 2015 | Maytag Bravos MTW6600T Top Load Washer
Washer makes loud grinding noise during agitation and does not agitate - it is a maytag atlantis.... fix or replace?
I suspect the thrust bearing kit is bad. This comes with great instructions and is easily replaced. I would recommend changing this before replacing the machine. You are not out much if it does not work, but I am confident you will get it going by replacing this! This is a VERY common problem with these washers and the new kit has been redesigned.
Kelly
Mar 21, 2011 | Maytag Atlantis MAV9750A Top Load Washer
Make loud noise during spin cycle
Washer may be out of balance, Move closes around in washer and restart
Oct 24, 2009 | Maytag Atlantis MAV6000 Top Load Washer
My washer make a loud squeal when the spin cyle is done
new brake assembly. please post your model number for further help TY
Mar 29, 2009 | Maytag Atlantis MAV7551 Top Load Washer
Maytag Washer HAV2558AWW loud noise during spin cycle
Your maytag is really an amana and the bearings are bad. Yes it does cost a lot. If i were you i would buy another washer. Get a whirlpool. (whirlpool now owns maytag)
Nov 16, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Loud noise on spin cycle
How did that answer get an 83% rating? It is absolutely useless. My washer has the exact same problem as described above.During the spin cycle it sounds like a jet engine. It kinda sounds like the belt hitting the drive wheel but may be bearings in the motor.
May 03, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Agitator is making noise
bearings in the transmission are going out. they are fairly cheap if you can change them yourself.
Mar 29, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Problems with MAV9501EWW Washing Machine :(
your seals and bearings are bad do you wash a lot of sandy gritty clothes if you do that is the cause of the problem
Jan 19, 2008 | Maytag Atlantis MAV9501E Top Load Washer
Maytag Atlantis MAV6260AWW Top Load Washer Logo
467 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
